05-18-2005, 05:42 PM | #1 |
No,I DON'T have Tourett's
Sloshy Doors
Washed the blazer this weekend, went to shut the door after wiping down the interior and it sounded like surf's up. Just a little reminder you all to make sure your door drains are clear and draining like mine now are.
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
05-18-2005, 10:14 PM | #2 |
I moved from dry Alberta to the coast of British Columbia last year. I parked my truck for a few days where it rained non stop. When I went to get in there must have been 4 inches of water in the doors! I poked around with a piece of wire to unplug the drains, and the water poured out of the drains. One of these days I'll have to pull the door panels to see what's in there, probably rust....
Toys: 72 K5 Blazer 74 Vette |
05-18-2005, 10:28 PM | #3 |
Also check your front fender and cowl drains. Also a good idea to shove a garden hose up into the fenders front and rear in a few spots to wash it out.
05-28-2005, 03:42 PM | #4 |
Time to replace window squeegy?I always do the rinse-out.It`s good to hose up and around between the bed panels.Don`t forget the rocker drains and cab supports.
05-28-2005, 11:54 PM | #5 |
PROJECT 7DEUCE
I always clean out my drains everytime I was the blazer or truck this way I don't have a water ride or a rusty ride..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-31-2005, 09:54 AM | #6 |
Good things to remember to keep those drains open! I will share a quick tip to remember. Speaking from experience (yes I am a bonehead @ times) DO NOT and I repeat DO NOT use the wire hook on the top of your drop light to poke in the hole to drain the water ZAP Lit me up a good.
67 short wide 355ci 3 on tree 69 short wide 250ci 3 on tree 68 long wide 283 3 on tree 72 2wd Blazer project 454 5 speed |
