11-16-2017, 12:23 PM | #1 |
Why won't my truck stay running
Just bought a 88 sierra with a 350 engine. Drove from Houston to the outskirts of San Antonio and it started sputtering, backfiring. Pulled over and it died on me. Now it will start up but if I take my foot off if the gas pedal it dies every time. Thinking catalytic converter or oxygen sensor but I'm not sure. I only have 20 miles I need to drive it to get it home and work on it. Any ideas how to do that without having to tow it?
11-16-2017, 03:06 PM | #2 |
Re: Why won't my truck stay running
I'd start by checking the timing. If that checks out, I'd look into a sensor like the IAC, MAP, or coolant temp sensor. The CTS and IAC won't throw codes if they go bad. The MAP should throw a code, so I would read the code if you have one.
Mike |
11-18-2017, 01:41 PM | #3 | |
11-18-2017, 08:00 PM | #4 |
I would be checking fuel pressure. It could just be a plugged up fuel filter.
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
11-18-2017, 09:12 PM | #5 |
Vacuum leak?
11-18-2017, 11:03 PM | #6 |
I agree vacuum
Leak. |
11-20-2017, 02:30 PM | #7 |
Sounds like a lean condition with the backfiring.. checking the fuel filter, fuel pump/pickup strainer on the sending unit and the pressure regulator on the TBI (those springs are prone to break).
Really need to verify fuel pressure at the TBI, or on the far side of the filter to make certain.
-- '67 Chevy Stepside 250 Inline 6 Megasquirt Fuel Injection T5 5 speed conversion Ferric Oxide impregnation throughout |
Tags |
88 sierra, catalytic converter, emissions system |
