Old 04-10-2017, 12:31 PM   #1
nikwho
nikwho's Avatar
18" x 9.5" wheel front wheel backspacing on '68 GMC w/ 73-87 crossmember
Hey guys,
I am wondering if anyone has experience running 18"x9.5" wheels on the front of these trucks? I'm looking at running 18" x 9.5" wheels on all four corners, and the only option available in the wheels that I'm looking at have 5.25" backspacing. From my measurements, it should work, but it's hard to tell how everything will move as the steering goes from lock to lock. Ultimately ill need to buy a wheel and install it to verify, but looking for insight from experiemced guys. I currently have stock control arms, but looking to run Ridetech or similar arms in the near future. Thoughts?
Thanks ahead of time!
Nik
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 04-10-2017, 12:47 PM   #2
chevy72blu
chevy72blu's Avatar
Re: 18" x 9.5" wheel front wheel backspacing on '68 GMC w/ 73-87 crossmember
My 72 has a 73-87 front end which I could measure for you, but I'm running an 18x8" wheel. Specs list it as 4.5" of BS and it fits great.
https://www.summitracing.com/parts/mbw-23207/overview/
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 04-19-2017, 11:15 AM   #3
nikwho
nikwho's Avatar
Thank you. My '68 has an '86 crossmember and 17"x8" wheels, so pretty close to yours. I'll just take some more measurements off of my truck with the steering lock to lock and should be able to figure it out. Was hopeful to catch someone running the wider wheels that has some insight.
Thanks,
Nik
'68 GMC - BBC/TH400
Old 04-20-2017, 08:48 AM   #4
68Stepbed
68Stepbed's Avatar
I'm running 18x9.5 wheels on all four corners. The inner lip of the wheel will rub the fornt of the lower control arms at full lock. I just removed part of the roll off the control arms just enough for clearance.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-21-2017, 09:35 AM   #5
nikwho
nikwho's Avatar
That's awesome. What's your backspacing?
'68 GMC - BBC/TH400
Old 04-21-2017, 12:46 PM   #6
68Stepbed
68Stepbed's Avatar
Originally Posted by nikwho View Post
that's awesome. What's your backspacing?
5.25"
Matt
Old 04-22-2017, 11:37 AM   #7
jessemthompson
I'm pretty sure I saw your truck in pigeon forge at the shades of the past rod run. It was park next to Arby's or Hardee's. can't remember which one. Very sharp truck.
jessemthompson is offline   Reply With Quote
Old 04-25-2017, 08:51 AM   #8
68Stepbed
68Stepbed's Avatar
Yeah, I was parked next to Arby's. Thanks for the compliment!
Matt
