03-23-2013, 11:44 PM | #1 |
truck is dead no clue why
Well I dont know what happend I went to drive it this morning and it started like it always dose. pulled out of the drive way made it about 200 yards and it started to stumble like I had it in to high of gear and died.
I put my foot to the floor when it was stumbleing at one point and it caught up a little bit. When I pulled back in the drive way my raidior was smokeing. the hoses where bulged out. There is no water in the oil. The only thing I have done to it was put on new valve covers. It back fired once as well. |
03-23-2013, 11:48 PM | #2 |
Re: truck is dead no clue why
do the new valve covers have crankcase ventilation, PVC etc...
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
03-24-2013, 09:34 AM | #3 |
Yes they do at one point I took the breather off I thought maby it was clogged. but it still barley ran. So when I got home I pulled off the valve covers and put the old ones back on still ran poor.
03-24-2013, 10:10 AM | #4 |
Active Member
Radiator smoking and hoses bulged out? Overheating can be caused by several things like fluild level low, thermostat not opening up, water pump worn or rusted out, cap defective or wrong type, clogged radiator or even leaking head gasket. Check the simpler things out first.
As for the truck not wanting to start, there may be some other issue involved along with the the overheating. Wait till it cools off and if it still won't start check for flooding or clogged fuel filters.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
03-24-2013, 10:42 AM | #5 |
I made sure the fluid was full and the cap is the same one that I have been useing. am going to replace the thermostat today and see if that helps. I am still stumped why changeing valve covers would make it stop running. The originals had 2 pcv holes in them one in each valve cover. The new ones have only one but I dont see why that would make it seem like its chugging and missing.
03-24-2013, 10:47 AM | #6 |
your timeline makes no sence a brief round trip of about 400 yards??
no engine i know of could overheat to such a degree in such a short time period r u sure that last time out it was not beat on hard and put away dry?
03-24-2013, 11:06 AM | #7 |
Bulging hoses sounds like your rad cap is too high of pressure.
Sounds to me like you have a head gasket leak. Happened to me once on an old tractor we had just had repainted. Picked it up from the painter put it on the trailer and it starts blowing antifreeze out the radiator cap all over the nice red paint. It didn't have time to get very hot either. Maybe ran for 3 mins. Should have replaced it before I guess. Can't expect much out of 55+ year old gaskets.
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton Last edited by Daner; 03-24-2013 at 11:10 AM. Reason: added stuff |
03-24-2013, 12:58 PM | #8 |
As far as the time line it warmed up in the drive way. So it was close to temp. I havent seen any water in the oil yet. Do you think that the valve covers didnt let enough pressure out?
03-24-2013, 03:40 PM | #9 |
Active Member
Valve covers won't cause a truck to come to a stop or get hot. It's possible a ton of oil got sucked in through the pcv hose but even then it would probably just blow smoke out the rear.
03-24-2013, 06:46 PM | #10 | |||
Good luck. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
03-24-2013, 07:51 PM | #11 |
Yep no clue just put new gaskets on the old valve covers and started it up drove it for an hr no problems. It dosent make any since
