Old 01-31-2013, 04:53 PM   #1
Mr onetwo
Mr onetwo's Avatar
Cab removal on 2002
Has anyone here attempted to remove the cab on an NBS truck?I picked up an '02 reg cab longbed truck real cheap, but it needs some rust repairs.I have already pulled the bed...very easy.I have a full set of GM service manuals and a GM body book, but there is no cab removal procedure anywhere.Has anyone done a frame off resto on one of these trucks?
Mr onetwo is offline   Reply With Quote
Old 02-24-2013, 08:43 AM   #2
TomL
Re: Cab removal on 2002
Hi, I haven't had any experience yet but i posted a similar question on January 21 titled "rusty frame 2002 Silverado" I am planning to purchase a new frame from Chevy and paint it along with other parts that rust before assembly. Have not been able to find any assembly manuals. I purchased the 3 volume set of Faxon manuals for my truck and while on the phone with Faxon they told me that car manufacturers will not allow assembly manuals beyond their assembly plants. Then after a model year is completed they recall the assembly manuals. I was told by friends to take lots of photos and i will create a log of every step i take and use zip lock bags for all small parts. If you find another source of information please let me know and i will do the same for you. Thanks, Tom
TomL is offline   Reply With Quote
Old 02-24-2013, 10:34 AM   #3
Mr onetwo
Mr onetwo's Avatar
Thank You very much Tom.I plan to pull mine next month after I get the crane project done.Check out a product called Z.R.C. to coat the frame with.It is a 95% zinc self-healing coating you can buy direct.It has tested to be equal to hot-dip galvanizing!A marine guy here swears by it for boat hulls,bridges,ect. I am going to use it for sure!Thanks again!
Old 02-26-2013, 06:42 PM   #4
rkn463
rkn463's Avatar
One thing you should be careful of if you have the radio controls on the steering wheel: that is all connected by what I am told is a ribbon cable that winds and unwinds. It is crucial that the wheel not be turned in relation to the steering box when it is put back together or it will trash the cable when you make a full lock turn. So when you get ready to disconnect the steering shaft get the wheels pointed straight, then disconnect the shaft and tie it in place. Then when you get ready to put it back together just make sure the wheels are pointed straight ahead again and you should be fine.
-Richard
PS: woo-hoo, my 100th post on this forum!
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 02-26-2013, 06:53 PM   #5
TomL
Hi Richard, I have the plain Jane cab so the only thing on the steering wheel is the horn and air bag. Great tip though. That could be disasterous if i went into it blindly and wound up the ribbon wire. Thanks, Tom
Old 02-26-2013, 07:37 PM   #6
rkn463
rkn463's Avatar
Now you have me wondering about those as well... Let me go check my other site.
-Richard
Old 02-26-2013, 07:45 PM   #7
rkn463
rkn463's Avatar
-Richard
I'm glad I checked, apparently the air bag is hooked to it too. Be safe, tie down the wheel!
Old 06-20-2013, 04:21 AM   #8
TomL
Hi,
You gave me some good advise about my 2002 rusty Silverado frame restoration. Have you finished your cab removal yet? I haven't gotten very far with mine yet except i'm clearing an area where i can work on it and gathering new parts. I might be in Maine soon if you have anything i can see and if you could stand a quick visit from a Chevy truck enthusiast. Thanks, Tom Linley 203-261-2288
Old 06-20-2013, 10:59 AM   #9
Mr onetwo
Mr onetwo's Avatar
Hi,
I have been very busy with all kinds of other projects...I plan to do this in July and will post pics.
Old 06-22-2013, 12:07 AM   #10
TexasSteve
TexasSteve's Avatar
A 06 Sierra is basically the same as a 02, so this thread may help or the OP should be able to help since he just got through doing it.
http://67-72chevytrucks.com/vboard/s...d.php?t=580625
2001 Yukon Factory Grey Metallic~2" DJM Key front drop/3" DJM Rear Springs~stock 16" chrome steel wheels~5.3/4L60E~Volante CAI w/under bumper air scoop~Magnaflow 10426 Bullet muffler~DDM LED all exterior lighting/55w-5000k HID Hi/Low/35w Fog
TexasSteve is offline   Reply With Quote
