Old 07-16-2010, 05:13 PM   #1
06raptor700
which motor for an ls swap
Other than the performance aspect of using an ls motor out of a car verses a truck are there any advantages to using one over the other. I will be using the truck (1966 c10)as a driver . Thanks
06raptor700 is offline   Reply With Quote
Old 07-16-2010, 07:09 PM   #2
clinebarger
Re: which motor for an ls swap
Price wise the Vortecs have the advantage, There usually at least a grand cheaper.
For a 1/2 ton driver I whould go with a 5.3/4L60E combo.
clinebarger is offline   Reply With Quote
Old 07-16-2010, 10:09 PM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
For the price, you really aren't gaining that much HP with the LS1 over a 5.3 or 6.0. But there is a good amount of weight difference. Best bet for good power and economy is the 5.3. If you are looking for more power, then look for a 6.0. Easy to make 500hp with a 6.0.
FWIW, I am getting 18-19 mpg in town, and 20-21 on the highway with a 5.3/4L60E. It was dyno'd at 266hp at the tires, which equates to almost 335hp at the crank. Plenty of power to move my 4000# brick right along.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-17-2010, 01:05 PM   #4
06raptor700
Is there a difference in the modifications needed to do the swap?
Old 07-17-2010, 01:28 PM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
new LSx motors can use the newer transmissions, or with an adapter use a non-computer controlled 200-4r, 700-4r, T-56, or whatever. I'm going with an MSD system to fire the plugs and a carb for air/fuel and non-computer controlled 200-4r, and you can also use aftermarket efi systems, or as most do... "transplant" the whole efi computer system, efi intake, fuel rails, injectors, sensors, and wiring harness into your vehicle...which generally leaves you looking for some way to interface with the computer and tune it yourself or get it tuned for best performance or in some cases...just to start.
Anything from the 4.8L truck motor...thru the 5.7L LS1 & LS6, 6.0 LS2, 6.2L LS3 car motors...and 6.0L LQ4-9, 6.2L L92, etc. truck motors....aluminum or iron block...they are ALL the same external size...and use the same mounting moints. Only the LS7 and LS9 are "different"...but not in physical size.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-17-2010, 10:27 PM   #6
85burb
85burb's Avatar
Go with the 6.0 if you dont you will prob regret it later. They are all close in price. At least where i looked and what i planed on doing. Any way you go you should be happy tho. They all great motors.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
