01-30-2008, 02:45 PM | #26 |
Re: front coilovers
Well, good news and bad news. Good new is that i got it all installed and it all fits well. Bad news is that the the springs are nowhere near stiff enough. When I lowered the jack down for the first time the truck was resting solid on the jack, I then put blocks under the tires and found that the coils were in total coil bind. Needless to say I need a much heavier spring so i ordered a set of longer and heavier Eibach springs from summit.
Anyhow heres some pics. |
01-31-2008, 11:12 AM | #27 |
Re: front coilovers
I hate to ask again, but can you identify what componets you used for your coil overs? What are the P/N? Thanks
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
01-31-2008, 06:45 PM | #28 | |
Re: front coilovers
02-04-2008, 11:31 AM | #29 |
Re: front coilovers
Got the new springs and they were perfect. Ive got the adjuster at about the halfway point so I figure theres enough adjustment to raise or lower the front end about 2 incher either way.
The ride, while definately stiffer than airbags isnt near as stiff as I feared it would be. Ive got the dampening adjustments on the shocks about 1/3 the way up and the ride while firm is in no way rough. Since the soft ride from the airbags was one of things I didnt like about them, all in all Im very pleased. Now its time for new wheels/tires, I sure hope tax time turns out in my favor. Heres a pic. |
03-24-2008, 03:49 AM | #30 |
Re: front coilovers
have you had a chance to try it out on the street yet
1986 swb...soon to be some weird pro touring look..but better 92 jeep cherokee.... crawler |
03-24-2008, 03:53 AM | #31 |
Insert Title Here
Re: front coilovers
sits nice.... now get some more pics
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
03-24-2008, 05:07 AM | #32 |
Re: front coilovers
yeah more pics and tell me how to get a set of those mounts
03-24-2008, 05:22 AM | #33 |
Re: front coilovers
More pics w/better lighting
03-24-2008, 06:39 AM | #34 |
Re: front coilovers
I took the body off so its gonna be awhile before I have more pics of the truck but with the body off its easier to see the coilover set up so I'll post some pics of that.
As far as the ride and handling goes, I coundnt be happier. Its still no sports car but its definately easier to drive fast than when it had the air bags in the front. I figure once I get front and rear sway bars on it itll actually handle pretty decently. I havent decided yet but I may do somethins similar in the rear. |
03-24-2008, 11:02 PM | #35 |
Re: front coilovers
any chance you could put a kit together and sell it to me. thats exactly what i want
03-25-2008, 10:31 PM | #36 |
Re: front coilovers
that does look good, but you didnt need to take the body off again just to get us pictures
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
04-21-2008, 11:10 AM | #37 | |
Restoring a 68 SWB
Re: front coilovers
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor Last edited by tdave00; 04-21-2008 at 11:11 AM. |
04-21-2008, 03:22 PM | #38 |
Re: front coilovers
I'm also curious about this . . ..... What bag set-up were you utilizing (bag manufacturer, shocks, configuration)?
04-22-2008, 05:44 AM | #39 |
Re: front coilovers
i would also like a kit if u could put one together. what price would u sell it for?
04-22-2008, 06:04 AM | #40 |
Re: front coilovers
i belive he is working on getting something made up right now, but im not 100% sure on that
04-22-2008, 09:17 AM | #41 |
Re: front coilovers
04-25-2008, 07:20 AM | #42 | |
Restoring a 68 SWB
Re: front coilovers
Ok..that makes sense, but wouldn't a sway bar take care of that?
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor Last edited by tdave00; 04-25-2008 at 07:21 AM. |
04-25-2008, 11:41 AM | #43 |
Re: front coilovers
Yeah, it really was about handling and I wanted a adjustable static drop. I liked the ride of the airbags but for what Im doing with the truck I wanted something with a little more adjustability. The cool thing about the coilovers is the huge array of spring weights/lengths available and the fact that the shocks are adjustable is pretty cool too.
Sway bars do help alot but theyre really only one part of the puzzle, same with the coilovers. Right now Im working on makeing the frame more torsionally rigid. SCOTI- the old set up was firestone 2600#? bags on modified(spring pocket cut out and bag plate welded in)stock lower arms. The shocks were from a E-150 ford van with fabbed upper shock mounts to correct shock alignment and change to a upper stud mount shock. |
10-22-2011, 05:29 PM | #44 |
Re: front coilovers
Hey guys, long time no post on this thread. Got the truck back together enough to set the ride height up on the ruck. Heres some pictures with the ride height I chose and some pics of the coilovers installed and loaded.
10-23-2011, 09:44 AM | #45 |
A guy with a truck
Re: front coilovers
Looks good! I like the ride height. Any concerns with the LCAs/tie-rods running 'uphill'? Are you running a drop spindle?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-23-2011, 10:22 AM | #46 |
Re: front coilovers
Glad to see your still making progress!!
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see." - Thomas Jefferson 72 C10 SWB "Work in Progress" |
10-25-2011, 08:52 AM | #47 |
Junior Member
Re: front coilovers
Crazy how this thread has been resurrected... We started working on a coil over front conversion a month or so ago...
10-26-2011, 01:40 AM | #48 | |
Re: front coilovers
10-28-2011, 07:42 PM | #49 |
Re: front coilovers
It appears that you dont have much suspension travel... It looks like the bump stops about an half and inch or so from bottoming out. I do realize that you have the truck adjusted very low. BTW very impressed by what you have done... looks great!
8.1l 496 4l80e |
10-28-2011, 11:43 PM | #50 | |
Re: front coilovers
