05-17-2017, 12:48 AM | #26 |
Re: Where to find 1972 door panel screws?
Are these the ones you're talking about? From one of our vendors here.
http://classicheartbeat.com/catalog/...r%20screws.htm
72 C10 lwb fleetside -stock 350/350 combo Last edited by 68 P.O.S.; 05-17-2017 at 12:56 AM. |
05-17-2017, 01:29 AM | #27 | ||
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-17-2017 at 01:37 AM. |
05-31-2017, 12:15 PM | #28 |
Bingo. I took a chance on Amazon, because it worked out cheaper. Same description, but no part number. Now I have 100 and they fit perfect. Thanks Smitty.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-31-2017, 01:32 PM | #29 |
Your welcome. I ended up taking a small piece of scrap 2x4, drilled an indentation with a 1/2 in. drill to hold the washer and used a file to remove material until the screw fit loosely enough to turn independently of the washer. Won't mess up new upholstery on door panels. Will post pictures when truck is finished.
Smitty '71 Short Fleetside Spring Valley, Ca. |
05-31-2017, 04:49 PM | #30 | |
Speak of screws, try finding factory type 8-32s for the rear lenses. Yeah common 8-32s work, but from what I see, none are available with the "thread forming" tips, and the fit isn't as good. No shortage here however, I just lifted off the driver.
05-31-2017, 06:27 PM | #31 |
I used the metal base model door panels and had them upholstered along with the factory buckets. and visors. I have a friend of my brothers doing all the work. Doing a great job, not cheap but will be worth every penny when he is done.
05-31-2017, 09:41 PM | #32 |
This is a poor picture of the seats and door panels. The headliner is the same color as the vinyl on the seat and sun visors used the material used on the seats. The tan color on the seats is the true color of the vinyl. Also match the seat belts and shoulder harness from Juliano's. The truck is being painted
Rain Forest Green.
05-31-2017, 10:05 PM | #33 | |
05-31-2017, 10:54 PM | #34 |
I'm getting more and more excited with each passing day. This was made possible by the inheritance my folks left me. And a great wife who said if I wished to fulfill the long time dream of a mighty fine truck this was the time. Drive train had been done and has been freshened up. All the rust repaired and several upgrades. Will post pictures upon completion.
07-26-2017, 10:06 AM | #35 |
Great thread and perfect timing! I was in the process of trying to figure out how to make the hump type finishing washers work, because I couldn't find any of those flush ones. I'm now the proud owner of 100ea Auveco part #16015...
Thanks again for an awesome thread!! |
