02-09-2009, 12:45 AM | #26 |
Re: Valve lash adjustment
man i love this place i'm getting ready to replace my valves and i found every answer here and in other places. this site rocks i'm glad there's people out there willing to pass on information like this so that people like me can learn it and pass it on wedgemon thanks for the picture of the valves i was getting ready to mess up and your info is great. i have only one question. the damper and timing tab is the damper the harmonic balancer i just want to do this right and once. i've done my engine work before i'm not affraid to take a motor completely appart and start from the bottom up. this is the 3 motor and i noticed that i been doing alot of things wrong. i think thats why my cam in my Z24 took a crap cause i didn't adjust my valves right.
http://67-72chevytrucks.com/vboard/group.php?groupid=37 73 C10 Fleetside If it ain't a Chevy it's foreign http://hotridesmag.com/ |
02-09-2009, 02:04 PM | #27 |
Yes, dampner and balancer are one in the same.
As for the pushrods, you'll still be able to spin them at zero lash, but it will be harder than with no preload (loose), I just spin the pushrod in my fingers till i feel a little resistance, then do my 1/2 turn past that and you are good to go! |
02-09-2009, 10:47 PM | #28 |
ok, seems as though i have them too tight then. i dont want to risk messing up all the work i just had done on my heads, so i'll re lash them tomorrow before i fire it up for the first time.
02-22-2009, 08:44 PM | #29 |
so what I'm getting is while tightening when resistance is felt stop and do the 1/2 turn or tighten till you can't spin the push rod. i just put a new cam in and lifters don't want to have to do this again lash thing is messing with me.
03-27-2009, 05:55 PM | #30 |
I know this is an older thread but I thought I'd keep it going with a quick question:
Adjustment of rockers is when engine is at TDC #1 and you can verify this by watching the #1 rods go up and then down? So that when you see the exhaust valve go up then down and then the intake follows suit, when the intake goes down your at #1 TDC; both valves closed. I assume when its at #6 TDC the valves are both open? |
08-25-2022, 04:08 PM | #31 |
Mine is 27 inches, but I’ve got a taller tire so it fills the gap better. (235/75/15)
‘66 Chevy C-10, long bed fleetside, 350, 3 on the tree, 4-7 drop. '77 chevy C-10 Custom Deluxe, 350, SM465 4 speed, flatbed. '80 jeep CJ-5. ‘14 Chevy 1500 Z71… |
08-27-2022, 07:29 PM | #32 |
08-27-2022, 09:14 PM | #33 | |
If it's a hotter can 3/4 a turn of preload is all I can add. |
08-29-2022, 12:07 PM | #34 |
72 C10 lwb fleetside -stock 350/350 combo |
08-29-2022, 09:10 PM | #35 |
I was always taught 1 turn out for teenagers and 3/4 turn for folks with money. Hard to float a loose valve lash on a hydraulic cam.
08-30-2022, 08:21 AM | #36 | |
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
09-25-2022, 12:55 PM | #37 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
09-30-2022, 09:13 PM | #38 |
One fool proof way is to loosen all the rockers and start with #1 tdc. Tighten all the play out any loose rockers. Turn the crank 90 degrees tighten all the play out the rockers. Turn the crank another 90 degrees tighten all the play out the rockers. Repeat until the crank has made 2 complete revolutions. Now all the rockers should be 0 lash, just tighten all the rockers 1/2 turn and you are done. Not the fastest way but it is fool proof if you are new to this.
10-15-2022, 10:12 PM | #39 |
Watch this https://m.youtube.com/watch?v=LIfZmC_KwGg
