Old 09-29-2022, 09:39 AM   #1
no1udknow
no1udknow's Avatar
low oil pressure after DOD/AFM delete
Hey guys, I have an 07 avalanche with a 5.3. I recently put in a AMS racing DOD delete kit in. Stock lm7 cam, lifters, valley plate etc. Now I have low oil pressure. Just under 40psi starting cold, but after running a bit drops to about 22psi. I don't want to damage the engine, looking for suggestions. it is a 2wd so I was thinking of dropping the pan to check the pickup o-ring, but I was reading about some bypass also. I'm an experienced mechanic (motorcycles and heavy equipment) but I just havent dug into LS engines yet.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 09-30-2022, 08:41 PM   #2
LS short box
Re: low oil pressure after DOD/AFM delete
Not an expert LS guy but if you used the stock valley plate could you be losing oil around the 'oil towers" in the block.
I haven't done a DOD block but I believe you either have to plug the block DOD towers or use a non DOD Gen 4 valley cover that had the o-rings in the valley cover.
LS short box is offline   Reply With Quote
Old 09-30-2022, 09:00 PM   #3
garyd1961
22 psi at idle is a plenty, not going to hurt anything
garyd1961 is offline   Reply With Quote
Old 10-06-2022, 04:46 PM   #4
LS short box
The LS6 in my 98 Wrangler runs about 25 psi at idle when warm. I run 10-30 Mobil 1. Been 15 years like that with no issues.
Old 10-07-2022, 12:39 PM   #5
biketopia
You're probably ok at idle, does it rise when you rev it? Like stated some people block the DOD towers when they do the delete, others just use a gen 4 valley cover and call it good. I did on the one I did and had no problems. Since you're 2x4 it's easy enough to slap a fresh o ring in the pump and check for blockage in your pick up. When you did the cam did you replace the cam retainer or re-use it. I've seen people have oil leak past the plate when re-used but usually it's a good leak and you have no oil pressure. Also, are you using a stock gauge or analog? If it hasn't been done it's a good idea to replace the OPS and the screen under it with new GM parts.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 03-21-2023, 12:20 PM   #6
no1udknow
no1udknow's Avatar
Sorry I didn't reply for so long..... so I pulled the pan and replaced the o-ring on the pick up and made sure the pickup was clean. It improved pressures a bit but nothing drastic. It runs fine but no oil light coming on now. Fixed a few ulother things. Also, the kit I bought came with a non dod valley plate, but I have heard the pressure can leak past the Orings and it's better to do the rivets, but for now it runs good with safe oil pressure.
If anything I may buy a new car, and this truck may become a donor for my 70 so I'm not overly concerned 😈
Built not bought!
Old 03-21-2023, 12:43 PM   #7
mongocanfly
Post Whore
mongocanfly's Avatar
no1..have you changed the oil pressure sender? theres a screen under it that can get clogged up..mine was, swapped it out and ive got good readings now
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
