Old 06-16-2019, 01:03 PM   #1
specialtyretail
So,, what else you got???
specialtyretail's Avatar
Set of alternator AND power steering brackets
SOLD,,,, THANKS.... Going to put a set of brackets out there in case anyone is having problems finding those brackets we put up,, and the lose. Alternator brackets AND power steering brackets. These are for a short water pump, small block engine truck. $140.00 shipped for both sets. Thanks, Fred.
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks....
Sorry, we CANNOT ship larger parts. Thanks.
specialtyretail is offline   Reply With Quote
Old 06-16-2019, 01:11 PM   #2
Harlowhead1972
Re: Set of alternator AND power steering brackets
Great price! Harlow
Harlowhead1972 is offline   Reply With Quote
Old 06-17-2019, 01:22 PM   #3
specialtyretail
Originally Posted by Harlowhead1972 View Post
Great price! Harlow
I do what I can. Thanks, Fred.
Old 06-17-2019, 02:37 PM   #4
Grumpy old man
Grumpy old man's Avatar
Sure , NOW you list a matching set after I had to look for months to find mine , Good deal for someone .
Old 06-20-2019, 07:51 AM   #5
specialtyretail
I was holding out on you. I am a tease like that sometimes. Thanks, Fred.
Old 06-20-2019, 07:50 PM   #6
Killer Bee
Killer Bee's Avatar
gonna ask in case you or someone else knows..
do these mount up with double hump heads?
also haven't checked which is installed but is short/long water pump otherwise interchangeable if I have the long on there?
I'm open to replacing the water pump with whichever fits a good belt drive setup..
I have a mystery SBC in the K20 with some shaky brackets and would be interested in these if applicable..
motor exhibits a lot of power so I'd like to clear up the peripherals and run it for a while..
if there's something I need to check, l greatly appreciate any suggestions..
I just scored a real nice 4wd shroud from a generous member and last year scored a nice factory K model fixed hub fan setup from another generous member..
want to tighten up the accessory drive end of the motor before I install fan/shroud..
thank you!
Old 06-22-2019, 09:36 AM   #7
painterljp
Does your heads have bolt holes in the front of heads? Most times they dont. If they do not these won't work. If they do they will work with a short water pump. For double hump. Heads you need different brackets that bolt to exhaust manifold on drivers side. Is your alternator on drivers side? Cause no where to bolt them.?? To head. Hope that helps.
painterljp is offline   Reply With Quote
Old 06-23-2019, 12:39 PM   #8
specialtyretail
Sorry for the slow reply, we were at the Street Machine Nationals trying not to drown. But is see painterljp pretty well summed it up. Thanks for the assist there.
Old 06-23-2019, 04:28 PM   #9
jamie72
jamie72's Avatar
would you happen to have just the upper alternator bracket you could sell?
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 06-23-2019, 04:53 PM   #10
specialtyretail
I do not, but check with Todd Rusk or 70 OriginalRust on here, they might cann help you. Thanks, Fred.
Old 06-24-2019, 03:07 PM   #11
Killer Bee
Killer Bee's Avatar
thank you Lois and Fred!
yer right, no bolt holes in the heads so I'll have to pass on these
nice brackets, sorry I can't use them, GLWS!
Old 06-25-2019, 03:22 PM   #12
painterljp
Have a drivers side exhaust manifold that is for use with those heads where the alternator bolts to a different set of brackets and to an ear on front of manifold. Will sell that side if you want to find the correct brackets for your setup. Maybe Fred has some brackets. For that manifold setup. Thanks for reply.
Old 06-27-2019, 07:43 PM   #13
specialtyretail
Right now, I do not. Thanks, Fred.
Old 06-27-2019, 08:23 PM   #14
Killer Bee
Killer Bee's Avatar
thanks again Lois and Fred!
when I get back from vacation in august I'll do some more research for exactly what I need..
I'm still waffling over a duramax swap so maybe one or the other will pan out soon enough
GLWS Fred!
Old 06-28-2019, 12:29 AM   #15
jocko
jocko's Avatar
I'll take em Fred, payment and pm sent. Thanks.
Old 07-05-2019, 09:42 PM   #16
jocko
jocko's Avatar
Received today Fred, all good, thank you - a pleasure as always doing biz w/you.
Old 07-06-2019, 07:49 AM   #17
specialtyretail
Glad to hear it. Always enjoy dealing with you. Thanks, Fred.
