Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 06-03-2016, 11:53 PM   #376
Cape Codder
Cape Codder's Avatar
Re: What did you do yo your truck today??
I have the wheels painted and ready to bolt on. No more red wheels going for a new look.
Interior pics of parts truck
Not bad except for cracked vinyl seat cover.
Cape Codder is offline   Reply With Quote
Old 06-04-2016, 07:46 AM   #377
That is a clean looking truck. I would have never guessed frame rot associated to it..
1981 GMC High Sierra SWB Stepside
"Whitey" 2002 Chevy Silverado 1500 SWB W/T
Board Vendors
Old 06-04-2016, 05:50 PM   #378
Cape Codder
PO was an over the road trucker. He didn't have a garage so put it in one of those canvas shelters with a dirt floor. I think between the moisture coming up from the ground and not getting drivin often enough to dry it out helped it's demise. Funny thing is the bottom pinch weld of the tailgate is rust free yet door bottoms are gone. I can break pieces of the frame off by hand from A pillar back to rear axle . All 4 wheels are new and upper control arms within last two years due to rust.
Old 06-10-2016, 01:04 PM   #379
MaritimeDragRacing
MaritimeDragRacing's Avatar
Still plugging away at the frame swap on my blue truck but now there's no pressure to finish it anytime soon. Picked up another truck last week - a 1994 Silverado 2500 with a 350, 14 bolt rear and every option known to man. No rust Alberta truck with only 160,000 kms - just needs a few new front end parts and a new windshield. Should tow a lot better than my old blue 1994 1/2 ton with a worn out 305.
http://www.maritimedragracing.com
Atlantic Canada’s #1 source for Drag Racing News, Race Results, Schedules and Track Information.
MaritimeDragRacing is offline   Reply With Quote
Old 10-18-2016, 06:45 PM   #380
Cape Codder
This thread is looking a little stagnant so I will post my new change. I had installed aux. backup lights a couple years ago to allow me to see while launching and retrieving my boats at night. I used regular tractor lights that were common at any parts store. Recently the left side bulb burned out ,it is three years old but has an hr. of time on it at best. I decided to upgrade to some LED'S off E-Bay and can't believe how much brighter they are. This shows the difference I did change both.
Old 10-19-2016, 05:21 AM   #381
That is some serious lighting. I like how everyone around you has the typical (for today) black/dark vehicle, while you stand out within the crowd.
Board Vendors
Old 10-19-2016, 06:19 AM   #382
Cape Codder
My daughter has the blacked out Silverado and the Jeep is my wife's winter ride. She has a silver Mustang convert for nice weather. The new color is different enough to get attention wherever I go these days.
Old 10-29-2016, 05:14 PM   #383
draper454
changed out the stock tail lights, put new led tail lights big differance
draper454 is offline   Reply With Quote
Old 11-01-2016, 11:47 AM   #384
Readyforduty24
i replaced my head lights, front turn signals and corner marker lights with a more modern looking style. i also replaced all the bulbs in the tail lights and back up lights with L.E.D.s. Then i replaced the fuel tank straps as the rear strap rusted through and my fuel tank almost dropped out from under my baby.
Readyforduty24 is offline   Reply With Quote
Old 11-01-2016, 01:11 PM   #385
Cape Codder
The future looks brighter
Old 11-01-2016, 06:36 PM   #386
Readyforduty24
yea, what sparked the whole light thing was i got pulled over by a cop in front of me one night because she said my lights weren't bright enough..................... problem solved, my new head lights have the ultra white bulbs in them. and all the other lights are LEDs as i said before.
lol
Old 11-05-2016, 06:51 PM   #387
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Started out doing the 4-Hi mod, and ended up removing the grille and lights as the passenger headlight and core support were damaged by a deer prior to purchase.
The circled area's are where the core support is bent from the deer. Not bad considering what a deer did to my S10 years ago. I'm going to pull this back out and line it all bad up.
You can see here the lower tab is broken off of the headlight.
The next two pics you can see the other damage to the light. The pins that you remove to pull the headlight are both damaged to the point they just spin and I couldn't remove the headlight. Which is what led to the grille coming off.
So I'm now looking for new headlights, matching turn signals (as the ones I have now are getting water inside) and I'm thinking of a new grille while I'm at it. May even put the 20" LED light bar behind the grille too.
Steve
2017 Silverado High Country - 5.3, 8spd, crew cab short box.
1991 C2500 - Silverado Trim, 4" spindle lift, 305, 4l60, 6 Bolt (light duty) 2500
1972 Plymouth Duster - 360, 904 w/ Reverse manual valve body, 8.25 rear w/ sure grip and 3.55's, Petty Blue...
Dalaigh is offline   Reply With Quote
Old 11-11-2016, 01:40 AM   #388
deejaaa1
replaced all the injectors from 6.2 to 6.5.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 11-22-2016, 01:43 PM   #389
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
I washed and waxed my ol girl.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 11-22-2016, 04:02 PM   #390
Tom
driving is in my blood
Tom's Avatar
Finished bleeding the second brand new master cylinder after the first was bad and finally drove my new disk rear brake setup. It was glorious.
-06 CBR600F4i: 110mph in 2nd at 14,000rpm= happiness.
-02 Suburban 4x4: stock
Old 11-22-2016, 05:16 PM   #391
deejaaa1
figured out the wiring for the Gear Vendors unit. now i turn 1800 rpm at 65 mph with 4:10 gears.
hauled some metal to the scrap dealer and got 25.00 for the pocket.
Old 12-08-2016, 11:55 PM   #392
udownwitkj
Bought a bumper off craigslist for $50. The next day went to local junkyard that had GMT400's everywhere, and bought Bumper filler, tow hooks, and air dam for $60. $110 well spent to get the front en looking spiffy as ever!!
picked up some H2 wheels. Listed the stock steelies for sale and someone came and boughtthem right off the truck before i could blink. So i had to buy new tires for the H2s. Went with 265-70-17 Cooper Discoverer. Got the center caps off craigslist today for $10. Im very happy with the look!!!!
udownwitkj is offline   Reply With Quote
Old 12-10-2016, 02:31 PM   #393
Tom
Tom's Avatar
Replaced my rear bumper after turning with a trailor too far and bending it up. Also added a tow hitch to prevent future bent bumpers lol. Also installed junkyard oem sunvisor rod as I'm tired of replacing the LMC rod every 6 months. The porsche tire compressor I had installed for my rear helper bags died so I'm piecing together a Mercedes air ride pump to replace it as well.
Old 02-16-2017, 10:40 AM   #394
schpeen
schpeen's Avatar
pulled some tape
1965 C-10 Stepside "8 ball"
1991 Silverado K5 Blazer "9 ball" 4x4
2016 Silverado single cab short bed p/u
1988 Mako Marine 23' walk around
2006 Mazda Miata black
2017 Corvette
schpeen is offline   Reply With Quote
Old 02-16-2017, 05:38 PM   #395
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-16-2017, 06:20 PM   #396
schpeen
schpeen's Avatar
Originally Posted by Kim57 View Post
Looks good.
Kim
i'm digging the cali colors the pics really don't do it any justice
i absolutely love it it is so much easier when you have a clear vision of what you want i have a clear vision of what it should look like when it's done and i see it coming to fruition right before me worth every penny!
2017 Corvette
Old 03-26-2017, 07:49 AM   #397
Mikefox
Hope she does great.
I have a rebuild in mine 4.3
Buttoning up the motor now.
I got a 04 nv3500 to put in to replace the getrag, mines a 91.
Going to the junkyard to find a shift tower. I hope
And if it quits rating drop the trans in
Mikefox is offline   Reply With Quote
Old 03-26-2017, 05:09 PM   #398
54 jimmy
54 jimmy's Avatar
changed the pitman arm on the 1996. steers better now lots of play gone in the wheel.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver)
1996 chevy k1500 reg cab 4x4(daily driver/wife's winter beater)
2002 gmc envoy xl (wife's daily driver)
54 jimmy is offline   Reply With Quote
Old 04-21-2017, 05:11 PM   #399
70c10guy
Installed a no hole front valence, cut holes and installed new aftermarket oem style fogs!
70c10guy is offline   Reply With Quote
Old 04-21-2017, 07:05 PM   #400
Cape Codder
Lights look good did the come with brackets to the bumper?
Copyright ©2000 - 2018, vBulletin Solutions Inc.
