Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 03-13-2017, 08:23 PM   #1
Dave0
Faux paint step by step
A couple people asked me to show them how I was reproducing the patina on my truck... I figured this was the better forum to put it in... There are some examples on this page of my build thread http://67-72chevytrucks.com/vboard/s...=702899&page=7
Keep in mind, so far I am only doing small areas. But will do a couple new doors and a hood later on... I will start off with a epoxy primed part for "actual" rust protection...
Pic 1, the colors I am using. All Krylon.
Pic 2, a primed card, using the same color primmer on the truck.
Pic 3, template and color for a rust spot, say a body line.
Pic 4, the rust spot
Pic 5, another color and a smaller slit to add some depth to the rust spot.
Dave0 is offline   Reply With Quote
Old 03-13-2017, 08:24 PM   #2
Dave0
Re: Faux paint step by step
Pic 6, rust spot
Pic 7, gold texture paint drizzled on
Pic 8, rust colored primer
Pic 9, red paint
Pic 10, sanding thru some layers, exposing the multiple colors under the red
Old 03-13-2017, 08:24 PM   #3
Dave0
Pic 11, laying on the step
Pic, 12 behind the cab
Pic 13, some cutouts in cardboard I use. For different effects....Gives you a better idea of the colors used too
Old 03-13-2017, 08:25 PM   #4
Dave0
I ended up spraying some more dark gray primer on the card (to "hide" some of the red) to match other areas of the truck. Every panel is different.
I already used some of these techniques in the first pic. I patched in the fuel filler location and spray bombed it... That rusty looking spot is the body line of the cab corner... Cheers!
Old 03-13-2017, 08:48 PM   #5
Dave0
Here is a spot in the roof where I welded a hole shut. I intentionally sanded a line in it and left a slight low spot in it. I used the dark gray primer and a another color that matched the rust... Is it spotless? No but it will blend in once its cleared...
Old 03-13-2017, 09:00 PM   #6
Dave0
RT Bed corner and fuel filler patches
Old 03-14-2017, 04:07 PM   #7
bs46488
That's pretty cool to see the before and after shots of the repairs.
Just curious, how exactly do you "drizzle" rattle can paints?
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 03-14-2017, 04:10 PM   #8
Dave0
Stuck the right size piece of copper wire in the end of the nozzle...Play with different sizes
Old 03-24-2017, 02:00 AM   #9
Az. Hank
Az. Hank's Avatar
That is one of the better "Patina" jobs I've seen. Thanks for the how to..
My 55 Build 55 C-4
Az. Hank is offline   Reply With Quote
Old 10-06-2017, 09:38 PM   #10
GAc10boy
GAc10boy's Avatar
This is pretty impressive. I'd like to see more. Maybe with the larger sections you mention. I've got some rocker/door bottom/fender sections that will need blending on my '65 over the winter. Was planning to have a buddy spray it with a gun and try to get right but these techniques might just work better, if i can get my colors right (hugger orange over light green with a ton of surface rust).
Thank for this!
- Robbie
Instagram: @c10clubgeorgia /@whitlock_garage
Paw Paw '68 508 Dark Blue Custom C10
Speedy '67 Short Fleet Custom C10
'68 GMC SWB Light Green LS Build
Shortbed Utility Box Truck (currently in pieces)
GAc10boy is offline   Reply With Quote
Old 10-07-2017, 09:34 AM   #11
Dave0
I will add some pics when I get to the doors...
Old 10-12-2017, 05:53 AM   #12
mongocanfly
I agree...looks great....I've seen so many fake patinas that just look awful...yours is one of the best fake jobs I've seen....you should do a howto video...
mongocanfly is online now   Reply With Quote
Old 02-17-2018, 10:39 PM   #13
Dave0
Some pics from my build....
Old 02-17-2018, 10:42 PM   #14
Dave0
All 4 of these corners are new metal....
Copyright ©2000 - 2018, vBulletin Solutions Inc.
