Old 03-13-2017, 09:02 AM   #26
69-72
69-72's Avatar
Re: Has anyone improved ride/handling in Jimmy/Blazer?
Is there a way to add a front sway bar without swapping out the front crossmember?
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 03-13-2017, 10:03 AM   #27
60case
I added a sway bar from a 1986 k20. I made these plates out of 1/4 steel. Works good. Uses stock cross member
60case is offline   Reply With Quote
Old 03-13-2017, 09:02 PM   #28
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Can you post more pictures of how this connects?
Smitty
71 C10 283/3SPD (I know its not original but I like the motor) 4 Whl Disks,Dakota Dash,Moved Fuel Tank,Frame Off
71 GMC 1500 Sierra Grande 350/700R4 3.42 rear, Repainted with my own hands and it looks Freaking Sweet.... http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 Suburban Former military GSA truck,,still solid as a rock! Its starting,,,350/700R4 3.42 rear, Dodge seats.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber...Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one.....Gen 5 5.3/8L90E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
71meangreenc10 is offline   Reply With Quote
Old 03-13-2017, 09:34 PM   #29
68c10airstream
68c10airstream's Avatar
I read through all of the posts an i'll add this idea! Add a plastic leaf spring liner designed to reduce inner leaf friction. I re-sprung my 48 willy's pickup after the stock 7 stack narrow set flattened out from a sbc v8. I did this the same time i put a scout disc brake front end under neath it and a ford axle out back and did the same re spring job in the rear. It made a world of difference with fewer leafs (4 i think) and reduced inner leaf friction was awesome!!
68c10airstream is offline   Reply With Quote
Old 03-14-2017, 12:42 AM   #30
Madtrucker
I've heard it's dangerous to have a front sway bar without a rear. If that's true, which seems to make sense make sure you do the rear first.
1968 k10 lwb-swb stepside
1936 chevy truck
1977 corvette
My 68 lwb-swb 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=527176
1972/68 blazer 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=641824
Madtrucker is offline   Reply With Quote
Old 03-14-2017, 12:04 PM   #31
60case
GM made millions of cars and trucks with front sway bar and no rears. I used a piece of steel 8x2x1/4 to make the brace for the bar mounting brackets. the spring top plates are from the 86 K20 the bar came from
Old 03-14-2017, 12:41 PM   #32
Coatingguy
Quick question on this subject,
Does anyone have the part number for the Redhead steering box that would fit a 1972 gmc jimmy 4x4? I'm only seeing boxes for 2wd applications on their website.
Coatingguy is offline   Reply With Quote
Old 03-14-2017, 03:21 PM   #33
GMC-YA68
GMC-YA68's Avatar
Part #2851 was the part number a year or so ago - you'll need to tell them if you want 15:1 or 18:1.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 03-14-2017, 06:19 PM   #34
71meangreenc10
Thanks for the pics, never seen this setup with the bar connecting to the axle before. Interesting...
Time to go square body hunting....
Smitty
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
