Old 03-14-2017, 10:40 PM   #1
STP67-72
STP67-72's Avatar
70 3/4 ton 4x4 Info. For bigblock
I have a local guy wanting to install a bigblock in a 70 4x4 suburban. What motor mounts will work best. Somebody told him valve covers on a big block will hit fire wall ??? Also HEI will be close. It's a 350- granny 4speed now. Thanks for any and all help !! I don't think they made 402 bb 4x4 suburbans ???
55 Chevy original swb (big back window)
61 Chevy bubble top (427-5 speed)
67 Chevy stepside (Krusty)
68 Chevy swb fleet (Lola)
68 Chevy swb fleet
71 Chevy swb fleet ( future PB project)
97 crew cab power stroke
07 SS Trail blazer
STP67-72 is offline   Reply With Quote
Old 03-14-2017, 10:47 PM   #2
ajviper
4x4 Guy
ajviper's Avatar
Re: 70 3/4 ton 4x4 Info. For bigblock
I have a 71 K10 SWB truck I put a 454 in. I used the stock small block mounts but I moved the motor forward 2 inches. No issues with firewall clearance.
ajviper is offline   Reply With Quote
Old 03-14-2017, 10:49 PM   #3
CG
BlahBlahBlah
I don't know the exact amount but the engine needs to be moved forward a couple inches. You should post this on the main board or the 4x4 area. Putting a big block in a burb 4x4 is no different than putting one in a pick up 4x4
Or Im slow and just have ajviper answer lol
Taking some time away ... Ill be back!!
Old 03-14-2017, 11:06 PM   #4
ajviper
4x4 Guy
ajviper's Avatar
Just an add-on. I moved my motor to the forward set of holes in the frame. I can grab some pictures of it tomorrow if you want me to.
Chevy Runs Deep.
1956 210 LS3 4L65E 3.31 Posi 12 Bolt
1969 Z/28 LS3 T56 3.73 Posi 12 Bolt
1971 K20 Custom 10 SWB 454/TH350/NP205 3.73
1972 K5 Blazer 307/TH350/NP205 3.07
1972 K10 Suburban Custom 10 350/TH350/NP205 3.73(Orig)
1973 Nova SS 355 TH350 2.73 Posi 12 Bolt
2010 2SS/RS Camaro LS3 T56 Aqua Blue Metallic
Old 03-15-2017, 07:50 AM   #5
STP67-72
STP67-72's Avatar
Yes. Send pictures. I will forward them to him.
68 Chevy swb fleet
07 SS Trail blazer
Old 03-15-2017, 08:48 AM   #6
LockDoc
The Original Thread Killer
LockDoc's Avatar
If he is going to use the stock BB exhaust manifolds he will have to use the '68-'71 BB frame brackets/perches. The BB manifolds won't clear the SB frame brackets/perches....
LockDoc
Leon
Old 03-15-2017, 01:37 PM   #7
ajviper
4x4 Guy
ajviper's Avatar
My friend had a 396 with manifolds in his K10 with the stock mounts. No frame cuts. Motor was in the stock position up tight on the firewall. I mocked it up and it will fit 2 inches forward with the manifolds I have. I will try to grab the numbers from those as well.
Old 03-15-2017, 02:34 PM   #8
LockDoc
LockDoc's Avatar
I don't know about the 4x4's but I know it won't work with the C's, I tried it.....
LockDoc
Leon
Old 03-15-2017, 05:09 PM   #9
ajviper
4x4 Guy
ajviper's Avatar
Sorry about it not being ultra nice looking under the hood. The truck is a daily driver so it isn't the prettiest.
The first picture shows the engine crossmember holes.
I can pull the HEI very easily without any issues or interference from the firewall.
I run a set of Hooker Competition Headers 2463HKR. The only tight spot is on the passenger shackle and a slightly shorter bolt took care of that problem.
I run 1972 2WD big block fan shroud and accessories.
When I installed the big block I also installed a set of new HD 3 leafs. I used polyurethane mounts on the engine. No issues with 3rd member to engine crossmember clearance or the oil pan hitting the crossmember.
If he wants to ask questions I can PM my number and he can call me. I am more than happy to answer any questions.
Old 03-21-2017, 09:31 AM   #10
olblue60@aol.com
member
I moved my engine forward as well. I moved it 1 7/8 inches but I believe it makes no difference. You will be happy with the extra firewall clearance at the distributor.
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
