Old 03-14-2017, 06:17 PM   #1
Jayman931
Jayman931's Avatar
Shock advice for 1969 with 2.5" Drop Spindles
I few years back I changed from drum to disc brakes with a 2.5" drop spindles. I probably should have changed shocks then but didn't have the extra cash...I do know.
I like the look of my ride. Its a tad bit lower in the front than back because of the drop spindles. I want to keep that look or maybe even back the back even with the front. I am worried if I don't get the right shocks it will mess with the ride height.
As of now my shocks are absolutely shot and it bottoms out if I am not careful
Any advice? I did a little research and what I found that sounds like it might work are the Bell Tech nitro2 drop shocks. I could swing springs if I had to.
Any help is much appreciated!
The stupidty of your actions is directly proportionate to the number of people watching you...
Jayman931 is offline   Reply With Quote
Old 03-14-2017, 08:43 PM   #2
bbbc10
Diggin The SquareLife
Re: Shock advice for 1969 with 2.5" Drop Spindles
get belltech shocks an lower the rear an don't raise the front to level it
bbbc10 is offline   Reply With Quote
Old 03-15-2017, 07:13 AM   #3
PGSigns
PGSigns's Avatar
I am running the belltech street performance shocks and like the ride. Shocks will not change the ride height. Put a set of 3" springs in the back to level the truck some and call it good.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-17-2017, 02:09 PM   #4
Jayman931
Jayman931's Avatar
Sounds like a plan. I am ordering these today! Thanks for the info.
Old 03-24-2017, 04:55 PM   #5
Jayman931
Jayman931's Avatar
Belltech Street Performers and the rear 3" Springs came in. As well as alum. radiator, fuel pressure reg and a few small things. Looking forward to a smooth install and a smooth ride
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
