Old 03-17-2017, 04:36 AM   #1
Skunksmash
Skunksmash's Avatar
How many of these do I actually need?
Soon I'll be installing 1990 model Suburban buckets in my 87 Silverado. How many brackets do I actually need, out of a suburban? I have 2, which I purchased from a member here a while back.
But how many do I actually need? Do I need 2 brackets out of a burb, or 4? And do I need anything for the back? Or do I just need concern myself only with the front?
Skunksmash is offline   Reply With Quote
Old 03-17-2017, 05:08 AM   #2
Skunksmash
Skunksmash's Avatar
Re: How many of these do I actually need?
To clarify, I'm asking how many of these things I need:
Old 03-17-2017, 05:10 AM   #3
Wgesnerjr
Active Member
Wgesnerjr's Avatar
I watched these videos a year or so ago as this guy goes through the whole process, including brackets.
https://m.youtube.com/watch?v=r2eCln-32zg
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 03-17-2017, 07:02 AM   #4
1968vetL-71
Junior Member
1968vetL-71's Avatar
just the 2 brackets. They go on the front inside tracks. You will need to drill the rear hole. You can just nut n bolt it or you can weld a nut on a small tab of metal, that way it has some area to tighten against the floor, not just the washer or nut. The outer tracks bolt to the existing holes front and back. I did this exact install on my 91 crew.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 03-20-2017, 02:17 AM   #5
Skunksmash
Skunksmash's Avatar
Thanks those videos are really helpful. I didn't know I could use the seat tracks off of a bench to help me get the buckets installed.
So really, that's all I need. Just the brackets I posted in the pic, and the old seat tracks. Would you say that is accurate? That is the way it looks anyway
Old 03-21-2017, 11:10 AM   #6
Wgesnerjr
Active Member
Wgesnerjr's Avatar
If the brackets would take the place of the stands he built in the video, I say go for it.
Take a bunch of pictures and do a post. Would love to see how they work.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 03-22-2017, 04:37 AM   #7
Skunksmash
Skunksmash's Avatar
I'll see about taking some pictures. I can't be sure if they'll be step by step, but I can take some pics of the process, here and there.
It looks like I'm going to have to have those brackets in the pic, welded in. I'll grind the off of the floor steel that they're currently welded to. Then they need to be welded to my floor instead.
Unless, I just make my own bracket like he did. Then I can just make bolt holes. I'd really, really like to avoid any welding.
Old 03-27-2017, 08:33 AM   #8
Skunksmash
Skunksmash's Avatar
I'd like to ask you guys' opinion.
Do yall think its a good idea to do this without welding? To just bend up the necessary iron pieces into the correct position, and then put bolts through the iron and into the floor?
Modern cars just have the seats bolted in, but a couple of these iron pieces are a bit... long. Not quite like a seat track that just sits on the floor.
Old 03-27-2017, 09:25 AM   #9
SCOTI
SCOTI's Avatar
It wouldn't be an issue just bolting them in place.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Copyright ©2000 - 2018, vBulletin Solutions Inc.
