Old 03-20-2017, 03:25 PM   #1
Donnie Lee
'50 Model AD Radiator Support Bolts
I'm looking for the radiator support to frame cross member bolts & shims as shown on sheet 2.11 in the 47-54 Factory Assembly Manual. Apparantly in our haste to dismantle last year these items got misplaced. I've looked in the LMC catalog & online, & Bowtie Bits online and have not found these listed. I also searched The Stovebolt and can up empty.
Appreciate any help.
Donnie Lee is offline   Reply With Quote
Old 03-20-2017, 06:09 PM   #2
solidaxel
solidaxel's Avatar
Re: '50 Model AD Radiator Support Bolts
From what I remember I think I just used some long 3/8 bolts and made shims from thick hard rubber, like old tires sidewalls
These shims are a critical adjustment point for fitting the hood to the cowl
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll ZZ4 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red 327
340hp 4spd 3:36
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wifes cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-20-2017, 06:19 PM   #3
jweb
jweb's Avatar
Here's the pads
http://www.classicparts.com/1950-54-.../#.WNBVG9IrKM8
And the bolts
http://www.classicparts.com/1947-54-.../#.WNBVWdIrKM8
They use carriage bolts, which you may be able to find locally. This allows you to loosen them when everything is put together and add shims.
jweb is offline   Reply With Quote
Old 03-20-2017, 06:29 PM   #4
solidaxel
solidaxel's Avatar
Carriage Bolts!
Any hardware store will have them!
340hp 4spd 3:36
Old 03-20-2017, 08:14 PM   #5
Donnie Lee
Thanks jweb & solidaxel, seems like i do remember a carriage bolt.
Old 03-21-2017, 12:51 PM   #6
_Ogre
_Ogre's Avatar
if it's anything like the tf mount there is also a tube spacer thru the rubber
this allows you to tighten the bolt without totally squashing down the rubber
photosuckit fix for chrome
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
