Old 03-20-2017, 10:17 PM   #1
Houston Ben
Houston Ben's Avatar
Is it my tune??
Hi All,
I have a weird problem (or maybe it is normal IDK)with my setup. 2011 truck 5.3 with original 6L80. When I mash the gas it will peel out 1-2 gears but once it hits 3rd it feels like the engine is stalled out (loss of power) and then will kick down and take off again.
I compare this to my Nissan Armada, when traction control kicks in, the Armada pedal has no response to input. It feels like the engine and trans stall or shut down until the wheels quit slipping and then it will take off.
Is this normal or do you think maybe the traction control fro 3rd gear is still on (if possible)?
I don't do this but every once in a while when I get a wild hair and there is no one around, but it still bugs the crap out of me as I don't think this should be happening.
Thanks for any help,
Ben
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
Old 03-21-2017, 11:14 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Is it my tune??
Could be a lot of things, including an issue with the transmission. Can you send me a copy of your tune?
Rob - http://instagram.com/hart_rod
As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17
FOR SALE: DBW pedal bracket, Pedal adapter for LS trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=651123
FOR SALE: ChubTubz, Rear tubs for slammed trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=675754
FOR SALE: Hood Brackets, Bolt in hood brackets! http://67-72chevytrucks.com/vboard/s...d.php?t=679945
1969 SuperBurb - 5.3/Magnacharger..http://67-72chevytrucks.com/vboard/s...d.php?t=200387
1968 Farm truck: LS3/6L80/TVS1900: http://67-72chevytrucks.com/vboard/s...d.php?t=358692
1968 SWB - SHIFTED: PB Xtreme DM/LS1/Dakota Digital/AccuAir/Vintage Air/...http://67-72chevytrucks.com/vboard/s...d.php?t=551258
1948 5 Window Chevy http://67-72chevytrucks.com/vboard/s...=122164&page=3
FAQ: http://67-72chevytrucks.com/vboard/f...play.php?f=220
Hart_Rod is offline   Reply With Quote
Old 03-21-2017, 11:48 AM   #3
Houston Ben
Re: Is it my tune??
Hi Rob, thanks for replying. No, I don't have a copy of my tune, wish I did. I will have to take it back in and get it checked out by a new tuner as the previous one who did the initial tune was a jack wagon!
I have thought about buying HP tuners since I have to spend another $400, but don't want to mess anything up and have no idea what anything is.
Old 03-21-2017, 12:12 PM   #4
Hart_Rod
Hart_Rod's Avatar
Re: Is it my tune??
It would probably be worth your money....
Old 03-21-2017, 12:36 PM   #5
Houston Ben
Re: Is it my tune??
If I buy, should I get the standard or professional? I have read the interface differences, but not sure if I need the pro stuff, what is your opinion Rob?
Old 03-21-2017, 12:50 PM   #6
sprint_9
sprint_9's Avatar
Re: Is it my tune??
I would go professional, I went standard and wish I would have went pro. The main reason being with the pro you can data log without having a laptop running the program.
The key benefit to this is you cant have a laptop hooked to the hp tuner box, and to a power inverter at the same time, it can burn out the hp tuner box. If you have a nice laptop or windows based tablet this likely isnt an issue, but it seems like most laptop batteries are junk after a couple years, leading to minimal data logging.
sprint_9 is offline   Reply With Quote
Old 03-21-2017, 03:55 PM   #7
Houston Ben
Re: Is it my tune??
Thanks for responding sprint, looks like I will be purchasing the pro.
Gunna need some help Rob!! lol
Old 03-21-2017, 07:57 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Is it my tune??
Your issue sounds potentially like Torque management, depending how its configured on your tune.
TM will act like a busted-ass traction control, that comes on at seemingly random and usually inopportune times.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-22-2017, 09:48 AM   #9
Hart_Rod
Hart_Rod's Avatar
Re: Is it my tune??
No problem. The first thing I would do would be to put everything in the transmission tune back to stock and just update your gear and tire size.
Agree a 100% Brew. I just fixed a friend of mines tune where nearly all of the torque management was turned off. It was banging 1-2 hard enough to break your teeth and 2-3 was super sloppy. I put everything back to stock and the truck shifts perfect now. Sometimes less is more....
Old 03-23-2017, 11:46 AM   #10
Houston Ben
Re: Is it my tune??
Alright, HP in ordered. Will let you know when in. Thanks for all the help guys!
Old 03-23-2017, 04:10 PM   #11
JMac11
JMac11's Avatar
Re: Is it my tune??
Torque management not being completely disabled was my problem for a while.
JMac11 is offline   Reply With Quote
Old 03-24-2017, 07:11 PM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Is it my tune??
FYI for everyone discussing TM. Its worth knowing that TM functions by pulling timing. The reason that it feels like TM affects other systems is that effectively, its the rest of the vehicle responding to what TM is doing. TM in GenIII's ends up working (and feeling) like an outside source rather than a cohesive part of the ECM system.
Bad things can happen when your pulling decently hard, TM gets activated and pulls timing, then deactivates and lets the timing back in. When this happens at the top of a shift, you can smoke a trans.
Old 03-27-2017, 09:35 PM   #13
Houston Ben
Re: Is it my tune??
Well....I got my HP tuners in, but can't figure out how to load it onto my surface pro 4. I have a buddy that is going to let me use his laptop tomorrow, so hopefully it can play nice with HP tuners.
I will keep all posted.
Old 03-28-2017, 07:56 AM   #14
Hart_Rod
Hart_Rod's Avatar
Re: Is it my tune??
I have on a surface pro with no problem. You should be able to download the software from their website.
Old 03-29-2017, 04:57 PM   #15
Houston Ben
Re: Is it my tune??
Well, apparently Windows 10 does everything automatically and I didn't have to follow the vague instructions the tuner came with.
Had my IT guy look at it and he figured it out lol. So tonight when I get home I will scan my engine and let you know!
Old 03-30-2017, 07:40 PM   #16
Hart_Rod
Hart_Rod's Avatar
Re: Is it my tune??
Looks like your tuner disabled most of the TM. What gear are you running?
Old 03-30-2017, 08:42 PM   #17
Houston Ben
Re: Is it my tune??
Hi Rob, running 3.42 years and 28" tires. I saw he got that correct. I will have to data log tomorrow and see what it records. I also noticed there were a bunch codes that are being thrown.....
Old 03-30-2017, 08:54 PM   #18
Hart_Rod
Hart_Rod's Avatar
Re: Is it my tune??
What codes?
Old 03-30-2017, 10:18 PM   #19
Houston Ben
Re: Is it my tune??
Too many to list, here are some of them:
P0010 intake (A) Camshaft Position Actuator Circuit/open (bank 1)
P0011 “ timing – over-advanced (bank 1)
P0016 Crankshaft Position – Camshaft position correlation – bank 1 sensor A
P0068 MAP/MAF throttle position correlation
P0101 Mass or volume air flow A circuit range/performance
P0102 Mass or volume air flow A circuit Low
P0103 “ circuit High
P0106 Manifold absolute pressure/BARO sensor range/performance
P0107 Manifold absolute pressure / BARO sensor Low
P0108 “ Sensor high
P0112 Intake air temperature sensor 1 circuit low
P0113 “ circuit high
P0116 Engine coolant temperature sensor 1 circuit range/performance
P0117 Engine Coolant Temp Sensor 1 circuit low
P0118 “ circuit high
P0120 Throttle/Pedal position Sensor A circuit
P0121 “ Range/Performance
P0122 “ circuit low
P0123 “ circuit high
P0128 Coolant thermostat (coolant temp below thermostat regulating temperature)
P0131 O2 Circuit Low Voltage (Bank 1 sensor 1)
P0132 “ High
P0133 O2 Circuit Slow Response (Bank 1, sensor 1)
P0134 O2 circuit No Activity Detected (bank 1, sensor 1)
P0135 O2 heater circuit (bank 1, sensor 1)
P0151 )2 circuit low voltage (Bank 2, Sensor 1)
P0152 “ High
P0153 “ slow response
P0154 “ No Activity
P0155 O2 Heater Circuit (Bank 2, Sensor 1)
P0171 system too lean (bank 1)
P0172 system too rich bank 1
P0174 system too lean bank 2
P0175 system too rich bank 2
P0201 – P0208 Cylinder 1-8 injector circuit / Open
P0220 Throttle / pedal position sensor / switch B circuit
P0222 “ low
P0223 “ high
P0230 Fuel pump primary circuit
Knock sensors low and high
Camshaft position sensor A
Ignition coil A-H primary /secondary circuit
Idle air control system RPM lower and higher than expected
Engine oil pressure sensor/switch circuit low and high
Old 03-31-2017, 10:13 PM   #20
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Is it my tune??
whoa
Old 04-01-2017, 09:34 AM   #21
Houston Ben
Re: Is it my tune??
I am wondering if these are just saved codes from when it was tuned? I can't emigine the engine being able to run with all of the codes.
Old 04-01-2017, 10:33 AM   #22
Hart_Rod
Hart_Rod's Avatar
Re: Is it my tune??
Has your check engine light been on?
Old 04-01-2017, 01:29 PM   #23
Houston Ben
Re: Is it my tune??
I am running my air temp, engine temp, speed, and RPMs off of a ScanGuage II, the only code that keeps popping up on that is B2AA or something like that, I would have to look again at it. It does not read or find all the ones in the HP tuner scan. I will take to truck out later today and do a live scan and see what I can come up with, too many kids in too many sports... lol
Old 04-01-2017, 08:51 PM   #24
Houston Ben
Re: Is it my tune??
Is there anyway to load a live log on here?
Old 04-01-2017, 09:00 PM   #25
Houston Ben
Re: Is it my tune??
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
