Old 02-20-2010, 11:59 PM   #26
zammer
Addicted user
zammer's Avatar
Re: Hydraulic Clutch Conversion 1965C10
O.K heres a couple pics I grabbed... hopefully there are enough angles to make sense of the headache i am having, i thought these headers would fit fine..
zammer is offline   Reply With Quote
Old 02-21-2010, 12:34 AM   #27
TR65
TR65's Avatar
Zammer,
In the immortal words of Bobby Bowden: dadgum
Probably the easiest thing to do would be find some more headers.
I have been thinking and you might could adapt and internal clutch slave to the old tranny but it would probably be tricky. I think that the clutch release surface and the input shaft housing are about the same in the new and old trannys.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 02-21-2010, 01:49 AM   #28
dan468
dan468's Avatar
Attachment 549859
Attachment 549860
Attachment 549861
Here's Frizzle's Clipsters:
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 02-21-2010, 08:30 PM   #29
LockDoc
The Original Thread Killer
LockDoc's Avatar
Originally Posted by TR65 View Post
Hey Dan,
I am driving the clutch cylinder from the left side of the pedal. The factory mechanical clutch goes thru the pedal mount pivot and drives a lever arm on the right side of the pedal. So there is no factory hole for what I am doing.
TR
TR,
I think Dan meant why didn't you use the hole that was already in the pedal, just below the one you drilled. I was wondering the same thing, it looks like it is only a 1/4" or so center-to-center below the elongated one.
LockDoc
Leon
LockDoc is online now   Reply With Quote
Old 02-21-2010, 10:20 PM   #30
TR65
TR65's Avatar
You know LockDoc,
As it turned out I think that factory hole would have worked out fine.
TR
1965 C10 SWB Fleet
Two owner
Old 02-21-2010, 11:53 PM   #31
LockDoc
LockDoc's Avatar
You know LockDoc,
TR
I may try using it when I do mine. Good thread. Thanks.
LockDoc
Leon
Old 05-29-2010, 06:09 AM   #32
raycow
Zammer, how is your header clearance on the right side? 60-62 bellhousings are set up for factory hydraulic linkage with the fork and slave on the right.
Ray
raycow is offline   Reply With Quote
Old 05-29-2010, 09:05 AM   #33
zammer
Addicted user
zammer's Avatar
The clearance on the right side was good, I ended up returning the Sanderson headers and I have some Hedman shorty headers now that work good... I have enough room to get across the frameto the block with the Z bar..
Old 06-13-2010, 01:10 AM   #34
Critter
Future TOTM Winner
Critter's Avatar
This is backing up a little bit, but I searched in Summit's website for your master cylinder part number 260-3374 and it brought up this, summit calls it a brake master cylinder.
And when serching summit for clutch master cylinders, I found this McLeod Kit for about twice the price. I'm confused?!?!? Are they the same kit and just because one is labeled as a clutch master cylinder it is considerably more??? Am I an idiot and missed something. Sorry to jump in the middle of your thread like this but I would hate to pay double for something if I don't need to.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 06-13-2010, 01:54 AM   #35
Captainfab
60-66 Nut
I believe Wilwood just calls them brake masters since that is the most common use for them. They will work fine as a clutch master cylinder. This is the one that I sell with my power brake conversion for the '60-'62's. It's a little cheaper as well.
http://www.summitracing.com/parts/WIL-260-1304/
Judging by the pic, that Mcleod unit is the same as the Wilwood one.....just a lot more $$
And when serching summit for brake master cylinders, I found this McLeod Kit for about twice the price. I'm confused?!?!? Are they the same kit and just because one is labeled as a clutch master cylinder it is considerably more??? Am I an idiot and missed something. Sorry to jump in the middle of your thread like this but I would hate to pay double for something if I don't need to.
Old 06-13-2010, 02:42 PM   #36
TR65
TR65's Avatar
What CaptainFab says is correct. What I used is called a brake master cylinder by Willwood.
TR
1965 C10 SWB Fleet
Two owner
Old 06-13-2010, 02:52 PM   #37
Critter
Future TOTM Winner
Critter's Avatar
Thanks guys, that's what I figured, just wanted to be sure. Great write up!
Old 07-12-2010, 02:09 PM   #38
Jim_PA
How do you know how much travel you need in the master cylinder? Can't you blow out the slave if you have the piston pushing in too far on the master?
I'm working on doing my conversion now, and it would seem you need to somehow measure how much "throw" to give the master cylinder???
Just want to make sure I don't run into any problems. And thanks for the write-up! - I ordered everything you did, but I went with a 7/8" bore master cylinder since I plan on flat-shifting at 6000+
I also used an Earl's fitting to convert from the factory slave fitting to a standard AN size. And I rigged up a remote bleeder hose too.
Jim_PA is offline   Reply With Quote
Old 07-16-2010, 10:11 PM   #39
Critter
Future TOTM Winner
Critter's Avatar
I dug around on the Summit site and it says that the Wilwood cylinder originally mentioned has a stroke of 1.10 inches, and the other Wilwood cylinder that Captainfab mentioned requires 1.40 inches of stroke.
Old 07-16-2010, 11:19 PM   #40
TR65
TR65's Avatar
Jim,
Good question. I don't know. Mine bottoms out before the end of the master cylinder stroke. Bottoms the slave out I guess. I am using the center pull slave cylinder on the T56. I must have a hard stop, seems to work OK.
Your clutch will be mighty quick with a 7/8" bore. I am thinking of going from a 3/4" down to a 5/8" to give more travel and less pedal effort. Truck is running now and clutch works fine, just a little quick.
Beware!!! The push rod must be close to centered at the bottom of the stroke. I lined mine up at the top of the stroke and then at the bottom the rod was cocked and ruined the cylinder bore and caused a leak into the cab.
Got a new cylinder and lined up the rod at the bottom of the stroke and it works fine.
1965 C10 SWB Fleet
Two owner
Old 07-19-2010, 11:02 AM   #41
Jim_PA
Thanks for the input -- After looking at my pedal, it looks like I'll be using the factory lever on the other side of the pedal assembly where the stock linkage attaches. It will need to be rotated so it's throwing more towards the firewall, rather than down, but other than that, it looks like it should work pretty well.
Old 08-21-2010, 12:59 AM   #42
Heater63
Heater63's Avatar
sdailey did you have any problems using the stamped Novak fork lever with the cast iron bellhousing? Did you have to machine the fork window open more? If so, what are you doing for a boot?
I am installing the Novak kit (HCRC 3/4") now and ran into this problem. I talked to them at Novak and they have just added more info about this issue to the website. If you use the stamped fork included in the kit, it is too wide for the cast bellhousing window with a boot. If you try to use your original forged fork lever, the slave does not align quite right, off about 1/2 inch. I am fabbing up a bolt-on cup to install on the forged fork to recieve the slave pushrod at the correct location. If it works, I will post pictures. It may be a quick and easy $2 solution.
also, the stamped fork requires the mushroom shaped fork pivot, not included in the kit.
the original forged fork uses the round ball type fork pivot.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 08-23-2010, 09:36 AM   #43
sdailey
The Few, The Proud
sdailey's Avatar
Yes sir I did have a problem with the fork not fitting the bellhousing opening. I informed Novak last year about this issue and they were going to update their information on their website, but I guess they never did until now.
I've attached a few pictures of the modification that I did to my bellhousing. However, I used my original pivot ball with the new clutch fork and best I can remember I talked with Novak about that and they said I could use my old pivot ball. I guess I'll figure out if it works or not when I finally get the truck back together. As far as the fork boot goes I used an original 67-72 boot. I took a razor blade and made a small relief cut where the fork slides through the boot. The flange area of the boot fits up pretty good to the opening of the bellhousing. It's not an exact fit, but it's close. Sorry no pictures of the boot installed.
Shannon
sdailey is offline   Reply With Quote
Old 08-23-2010, 10:55 AM   #44
Heater63
Heater63's Avatar
Thanks!
I may go that route, but I'm playing with a cheap adapter to still use the forged fork. I'll post some pictures soon.
BTW, thanks for your service Marine!
-Tad
292 + TKO500
Old 07-14-2012, 11:01 PM   #45
Hart_Rod
Hart_Rod's Avatar
Sorry to bring up an old thread, but a project truck I purchased has the T56 in it. I still need to hook up MC and I was wondering how everyone's turned out? Is there a max throw on the slave? Any lessons learned? Thanks in advance.
Rob - http://instagram.com/hart_rod
As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17
FOR SALE: DBW pedal bracket, Pedal adapter for LS trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=651123
FOR SALE: ChubTubz, Rear tubs for slammed trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=675754
FOR SALE: Hood Brackets, Bolt in hood brackets! http://67-72chevytrucks.com/vboard/s...d.php?t=679945
1969 SuperBurb - 5.3/Magnacharger..http://67-72chevytrucks.com/vboard/s...d.php?t=200387
1968 Farm truck: LS3/6L80/TVS1900: http://67-72chevytrucks.com/vboard/s...d.php?t=358692
1968 SWB - SHIFTED: PB Xtreme DM/LS1/Dakota Digital/AccuAir/Vintage Air/...http://67-72chevytrucks.com/vboard/s...d.php?t=551258
1948 5 Window Chevy http://67-72chevytrucks.com/vboard/s...=122164&page=3
FAQ: http://67-72chevytrucks.com/vboard/f...play.php?f=220
Hart_Rod is offline   Reply With Quote
Old 07-14-2012, 11:47 PM   #46
dan468
dan468's Avatar
I didn't mess with it, I went with manual clutch
68 C-10
Build thread
Old 06-08-2013, 10:10 AM   #47
Ta2Don
Ta2Don's Avatar
Been keeping an eye on this thread, and I can't wait to get this far with my build... Thanks for the great info
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 02-20-2014, 04:01 PM   #48
z50sto
How long were your pieces of 1/2 and 3/4 bar?
Hey guys,
Here is one way to add a hydraulic clutch master cylinder to a 65C10.
TR
z50sto is offline   Reply With Quote
Old 02-20-2014, 10:42 PM   #49
TR65
TR65's Avatar
Z50,
The 1/2 bar was 3-7/8" long. The 3/4 bar was 2-3/8" long.
The main thing is that the alignment be very good with the master cylinder bore.
Bye the way I have been running this rig for several years (20k miles) and it has worked flawlessly.
Good luck,
TR
1965 C10 SWB Fleet
Two owner
Old 06-04-2014, 08:00 PM   #50
68_chop_top
68_chop_top's Avatar
I have been running this setup for 50k miles and works alright. I am on my second slave cylinder as the aluminum housing wore out by the steel piston. Still a good setup. I wished there was a better slave cylinder made of cast iron. Any ideas?
Mine is chopped, has a clutch, and a big block.
68_chop_top is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
