Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 02-12-2017, 07:22 PM   #1
dccubby
rocker repair
Just curious if anyone in NJ will change my rockers.
dccubby is offline   Reply With Quote
Old 02-20-2017, 06:45 PM   #2
pwdcougar
pwdcougar's Avatar
Re: rocker repair
It's a lot of work. Have you been to any local shops yet? Up in northern NJ "restoration" shops will do it at a labor rate of over 100 bucks an hour.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1968 2WD GMC Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 02-20-2017, 10:36 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: rocker repair
I was told $1500-1800 for both sides, primered
Clyde65
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-21-2017, 08:21 AM   #4
dccubby
Re: rocker repair
Thanks, i was just curious about the pricing if anyone had it professional done. i think it is a little out of my price range, so i will attempt to do it my self. I am pretty confident with all the information on the web on replacing them, that i can do it. if it cost only like 500 to have it done would of been alot easier to pay. lol
Old 02-26-2017, 04:09 AM   #5
El Dorado Jim
Re: rocker repair
I may do my own also, am nervous about doing it though...
El Dorado Jim is offline   Reply With Quote
Old 02-26-2017, 01:27 PM   #6
dracko
dracko's Avatar
Re: rocker repair
Just a word of caution, if you decide to do it yourself. Try to do a full mockup before welding everything. My front floor braces were still good so I used them as a base for setting the floor/rockers up and for some reason they ended up 1/4" narrower on both sides. So the doors hung out over the rockers. Needed a lot of work to get things flushed up.
dracko is offline   Reply With Quote
Old 02-26-2017, 04:54 PM   #7
dccubby
Re: rocker repair
Thanks ill take any help that I can..luckily my floor and inner rockers are solid
Old 03-04-2017, 11:28 PM   #8
65truckowner
65truckowner's Avatar
Re: rocker repair
Make sure before you weld the rocker in place to use a couple screws to hold it in place and hang the door and make sure it all lines up. If not make the adjustments then weld it.
65truckowner is offline   Reply With Quote
Old 03-05-2017, 10:29 AM   #9
Bigdav160
Bigdav160's Avatar
Re: rocker repair
That's crazy. After you've done a couple they can be done pretty quickly.
Both, probably less than a day unless they discover more damage underneath.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-05-2017, 10:37 AM   #10
dccubby
Re: rocker repair
From what I have been reading i think gmcpaul is the place to buy the parts
Old 03-21-2017, 09:50 PM   #11
hugger6933
Re: rocker repair
Most likely there will be more to it once the outer rocker is off. Almost all are gonna need inners and possibly the floor section. If all that has damage it isn't out of the realm to need A and B pillar repair. That is what really eats up the shops time. as far as just outer rockers yeah. I'd do $500 for the pair into high build ready for paint but like said above if you have to replace a lot more once you get in there that is when it could get into cubic dollars. Good luck too bad your not closer.
hugger6933 is offline   Reply With Quote
Old 03-22-2017, 05:40 AM   #12
GR8-68
GR8-68's Avatar
Re: rocker repair
Check Coopers restoration parts they have great pricing and quick shipment, I ordered a set of door skins on Sunday and they came yesterday
Good advice from the others though, test fit with doors in place and use a couple screws to hold them in place while you tack them into place. Also like said already expect more hidden problems once they are removed assuming you are replacing rust damage
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Bed wood floors" For price requests, shipping quote or questions please email at: lgrant@dixoncabinetry.com
"Project 68"
"Project 72 Monte"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 03-25-2017, 09:00 AM   #13
lks dcvn
lks dcvn's Avatar
Re: rocker repair
Rockers aren't that bad if you get quality parts. If you get a set of bad ones - you will spend hours to have them line up and look right. Also, as mentioned, there is a high chance there is more rust behind them once you remove them.
There are plenty of how to videos on you tube and build threads on this site. If you don't have a welder - that might prevent you from getting this done cheap as well.
lks dcvn is offline   Reply With Quote
Old 03-25-2017, 09:04 AM   #14
dccubby
Re: rocker repair
I agree with everything you guys are saying. And i think ive come to the conclusion, due to spring and weather is changing i will leave alone for now and do in winter so i can take my time and do correctly instead of rushing.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
