Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-24-2017, 01:32 AM   #1
chevy72blu
chevy72blu's Avatar
72 water temp gauge grounding? Also questions about printed circuits
I have a damaged printed circuit and I plan on ordering a new one. I just installed a box body voltimeter but Im having issues with the temp gauge.
About a year or so ago I managed to get my water temp sensor reading correctly by installing a ground wire between the column mount and one of the terminals. Its been a long time and I dont remember which of the 4 posts is the ground? Its tough to guess and check while fighting the oil pressure connection each time.
Also, being again that I'm working with an old hodge podge of parts, I'm missing some of the terminal nuts. Being resourceful, I pulled the lower one from the fuel gauge (unused) to use on another terminal, and this caused the fuel gauge to no longer function. I dont see anything in the printed circuit that connects there, so I'm a bit confused. Does that nut ground itself to the tin housing?
Lastly, what diameter nut are the terminal connections?
If you cant tell I'm electrically 'tarded and its been years since I wrenched on one of these things. Thanks for the help!
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 02-24-2017, 02:35 AM   #2
chevy72blu
chevy72blu's Avatar
Re: 72 water temp gauge grounding? Also questions about printed circuits
answered here: http://67-72chevytrucks.com/vboard/s...d.php?t=648701
I'd still like to hear your thoughts on the thread diameter and pitch, as well as the self grounding issue. Thanks
RIP EastSideLowLife
Old 02-24-2017, 08:33 PM   #3
ray_mcavoy
Yes, that lower nut on the fuel gauge connects the gauge to ground via the tin cluster housing.
If I remember correctly, the studs on the backs of the gauges have #6-32 threads.
ray_mcavoy is offline   Reply With Quote
Old 02-24-2017, 09:12 PM   #4
chevy72blu
chevy72blu's Avatar
Got it wrapped up today, thanks! It seems like 95% of car electrical issues are due to grounding...
RIP EastSideLowLife
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
