Active Member
![]() Join Date: Nov 2013
SM-420/Pontiac engine
Will the SM-420 tranny bolt up to a Pontiac 389 or 400 block? This would be in a '65 GMC.
1962 C30 flatbed dually, 283\4 speed, 5.14's |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: SM-420/Pontiac engine
It should bolt right up to a Pontiac bellhousing as long as the center bore is 4-11/16". But then you have the issue of having to support the rear of the trans since you will no longer have a crossmember mounted bellhousing. The SM420 does not have provisions for a mount.
Might make one of these work. And use it with the stock bell. Don't know if you could make it work with a manual though? Find a sm465 that has a mount?
1961 chevy K10 my build is------------61K10 build |
Fabricate till you "puke"
The Olds & Poncho, bolt the starter to the dr side of the block . Buick must be on the pass side , as the Chev ....as all the BOP stick bells that I have seen , had provisions for a starter on either side? The adapter wont work for this app, but would work on an auto trans swap. You could use the BOP bell, & swap to a car type trans, that mounts @ the rear cross member under the trans....or possibly use a scatter sheild, & weld the mounts on the bottom to mount to your bell cross member. longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Thread Tools | |
Display Modes | |
