Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 03-18-2017, 09:13 AM   #1
blazer2007
wiring stock temp gauge separate ?
I need to wire my stock temp gauge separate from the circuit board.There are no markings which is pos. but I think the bottom brass stud is pos. and the the top brass one is sender which has the ceramic and the sliver stud would be pos.
blazer2007 is offline   Reply With Quote
Old 03-18-2017, 10:47 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: wiring stock temp gauge separate ?
That might get you in trouble.
Name:  temp gauge.jpg
ignore the add resistor advice. It is for gauges that read too hot.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-18-2017, 02:24 PM   #3
blazer2007
sorry forgot to say is a 84 style gauge and has only 3 studs.
Old 03-18-2017, 02:47 PM   #4
blazer2007
I don,t see why I could get in trouble,all I,m doing is changing from the circuit board wires to my own. The reason I,m doing this I changed from aftermarket gauges to stock but the temp sending unit wire is wrapped up nice and neat in the harness going to the starter and would be easier to make my own wires than take the harness all apart.
Old 03-19-2017, 01:37 AM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Well you threw me a curve with this one. I thought you were talking about a 67-72 gauge.
As you can see the bottom silver post is grounded to the cluster and you stated that you thought was Pos. Which is why I said you might get into trouble.
If you ran a positive wire into a grounded post then you'd have a short and trouble.
So what cluster do you have? the 67 to 72s were the same and the 73 to 87s were about the same. If you have an 84 cluster you can just follow the circuit board wires to the gauge to see which is positive and which is the sender for your 84 gauge.
You might be able to get a better answer on the 84 truck forums, but if you use an ohm meter. and check continuity then you can tell which post is the ground post for the gauge.
Most all the gauges use a green wire for the sender to the cluster plug and a pink wire to the power (pos) post. I looked but I didn't find a circuit diagram or temp gauge that showed the back with the correct wiring. I will keep checking because I am curious.
VetteVet
Old 03-19-2017, 09:13 AM   #6
blazer2007
Ok thanks I will take a pic of the gauge.Sorry about the curve,I always think everyone knows what I,m working on.
Old 03-19-2017, 09:15 AM   #7
blazer2007
I don,t know what cluster I have,I,ve collected about 4 of them
Old 03-19-2017, 02:00 PM   #8
halfstep
Active Member
vette vet - I like the new and improved imagery you're using for us!
halfstep is online now   Reply With Quote
Old 03-19-2017, 05:54 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
This is the 67/72 cluster.
And this is a newer model but I don't remember the year(s).
VetteVet
Old 03-19-2017, 06:03 PM   #10
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's a handy thread that will save you time and let everyone know what your details are. I.E. The year, style, engine, trans, and anything else you might want to list.
When you are done just click save signatureand you're done.
http://67-72chevytrucks.com/vboard/s...d.php?t=703123
VetteVet
Old 03-19-2017, 06:19 PM   #11
blazer2007
well I made a mistake,I will get my poop in a group and try and do a better thread for my problem . I ended up working 7 days a week for the last 6 months and in a hurry. I try to ask questions with out much thought of what I,m typing.
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
