Old 03-19-2017, 07:51 AM   #1
Jemezcrusher
235 timing cover blocked
I am putting new gaskets and painting my 235 before reinstalling in my 50 3100. There was a bunch of silicone gooped at the bottom of the timing cover on the outside.
When I got it open, I found that there were silicone plugs in the two holes that allow oil to come through from the pan. There was enough of it protruding through that it had to be intentional.
This can't be good long term and will certainly limit the amount of oil that makes its way to the timing gears.
Just curious to see if anyone has seen this practice or if there is a valid reason to block these two holes off?
Jemezcrusher is offline   Reply With Quote
Old 03-20-2017, 09:05 PM   #2
truckdude239
truckdude239's Avatar
Re: 235 timing cover blocked
Do you have a picture i cant quite picture what you have
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 101kmiles
2002 Honda Accord 4 door With 275k(sisters car)
1998 Honda Accord 4 door with 318k(brothers car)
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-21-2017, 09:50 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by Jemezcrusher View Post
... Just curious to see if anyone has seen this practice or if there is a valid reason to block these two holes off?
Never a good reason to block any oil passageways. I suspect the holes may have been inadvertently blocked with excessive use of silicone gasket sealant when trying to stop a leak.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
