Old 03-19-2017, 04:45 PM   #1
63C20
63C20's Avatar
Edelbrock or Holley?
my new engine will be here today, its my driver while i build my new motor. i have never had a holley, does it get the vapor lock issues like edelbrock when it gets hot? what should i run?
63C20 is offline   Reply With Quote
Old 03-19-2017, 05:38 PM   #2
geezer#99
geezer#99's Avatar
Re: Edelbrock or Holley?
A holley with the float bowls extended front/back might have a problem but not like an eddy does.
Doesn't hurt to use a heat shield though.
https://www.holley.com/products/fuel...s/parts/108-70
geezer#99 is online now   Reply With Quote
Old 03-20-2017, 12:09 PM   #3
63C20
63C20's Avatar
i dont know what you mean by eddy?
Old 03-20-2017, 12:18 PM   #4
geezer#99
geezer#99's Avatar
EDDYBROCK!
AKA edelbrock.
Slang is eddy.
Old 03-20-2017, 01:20 PM   #5
truckster
truckster's Avatar
Perhaps you already have your mind made up, but why not a Quadrajet? There's a reason they were installed on millions of GM vehicles. They're dependable, efficient, and provide lots of power.
truckster is online now   Reply With Quote
Old 03-20-2017, 09:19 PM   #6
crazy longhorn
Fabricate till you "puke"
If you want a set it & forget it, use the insulator gasket under the Eddy carb! I will say that I can tune the snot out of a Holley carb....but if you are not into tuning( DD), cruiser, forget it. As far as the Q-jet carb....many guys stay clear, not that it a bad carb, but it is more complex to tune. I spent 3 weeks tuning a Q-jet....after it was done , it was badder than the last Holley that I ran on that combo! longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-21-2017, 06:23 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Holley's get a bad rap only because people tinker with them too much and then can't get them tuned back properly. Any Holley carb can be a set it and forget it type of deal. I've been running Holley carbs on the streets for eons and have never had to fiddle with them all the time. The ONLY time I've constantly fiddled with Holley carbs is at the drag strip.
You couldn't pay me to use an Edelbrock/AFB carb.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
GASoline71 is offline   Reply With Quote
Old 03-21-2017, 06:52 PM   #8
crazy longhorn
First off, I wont have anything bad to say about a Holley carb....out of the 3 carbs mentioned, I feel that it comes down to personal preference/tuning abilities. On the track, run a Holley, or quick fuel,ect. On the street, you can run any of the 3 listed, but i feel that it is once again a personal preference. I have ran 2 Eddys, & a Carter on the street, in a cruiser style app....with no issues. they do need the insulator gasket under them, & do not like more than about 5psi on the fuel pump........Longhorn
Old 03-21-2017, 09:17 PM   #9
TJ's Chevy
Chevy I6 and GMC V6 Nuts
TJ's Chevy's Avatar
I've run my 600 cfm edelbrock for 5 years now without on issue. Been on two engines to. Currently on my daily driver.
"6 in a row makes it go!"
"I prefer a buzzin half-dozen"
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-21-2017, 10:41 PM   #10
my56chevytruck
my56chevytruck's Avatar
Years gone by, I owned nothing but Holley's, all sizes and in all types of cars. Mostly 60's muscle cars. Since then I've been using Edelbrocks and have found my favorite brand. The easiest carb to install and run. Little to no adjustments necessary. Won't go back to Holley's now.
RUBBER DOWN AND HIT THE ROAD!!!
my56chevytruck is offline   Reply With Quote
Old 03-22-2017, 10:12 AM   #11
Marv D
Registered Truck Offender
Marv D's Avatar
Coke, Pepsi or Mt Dew???
I've ran edelbrokes , Holleys, Carter and Rochester Q-jets, Holley MPFI Holley TBI kits,, and we all have our favorites and our nemesis. ANY of them can be a POS right out of the box, and likewise any of them can fit an application well.
Thinking ANY CARB is an out of the box, plug and play, perfect tune carb is foolishness.
Edelbroke carbs are cheap, and as long as you get fuel pressure in range for the carb, and your free O2 / vacuum signal is close, they will get you from point A to point B.
Go to the track and you won't see any of the quick cars running Edelbroke carbs, but you won't see them running ANY vacuum secondary carb.
Likewise any if efficiency / emissions and good tune is a concern,,, you can't compare a feedback EFI with ANY carb.
So if your not looking for all out POWER,, and not looking for ultimate efficiency perfection,,, then pick your poison...
So I digress,,,, Would you like fries with your Coke / Pepsi / Dr Pepper???
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 03-22-2017, 01:38 PM   #12
63C20
63C20's Avatar
i opted for neither, i got a nicely tuned QJ now i just need to figure out all the darn vacume posts on it
Old 03-23-2017, 10:06 PM   #13
crazy longhorn
Congrats on your choice.... A well prepped Q-jet will run nice on the street, & give decent mileage.If you post a pick on the carb, I can get into the Q-jet manual, & help with the vac fittings....longhorn
Old 03-23-2017, 10:12 PM   #14
franken
I wonder about the Holley spreadbores. Cheap, simple carbs meant as replacements for spreadbores of the era.
To me, the Holley seems more simple, and simple makes me happy.
franken is offline   Reply With Quote
Old 03-23-2017, 10:45 PM   #15
crazy longhorn
I ran the Holley spread bore carbs, & will say that they were an improvement, on a worn out Q-jet....but I have built/prepped a couple old Q-jet carbs. If that Q-jet is prepped right on, it will be the sweetest carb that you will run on the street Perf/mileage. As Marv stated, "would you like pepsi,coke, or mt dew with your fries"? Longhorn
Old 03-24-2017, 12:21 AM   #16
63C20
63C20's Avatar
It's a 17082226
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
