Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 03-20-2017, 11:51 PM   #1
70c10guy
4 high AND headlight relay mod!
Hi all, truck is a 93 c1500 with composite headlights. I've seen the guy on here selling his heavy duty harness with the 4 high mod that included a total of 3 relays. Doesn't look like he's available anymore so I was wanting to do it myself. I've done the Headlight relay upgrade on my 70 c10 and was pretty straight forward. I want to do it on my 93 but I'm not sure WHERE to add the 3rd relay for the 4 high mod. Do I add it after the relays on the light side or the truck side of the relays from the headlight relay upgrade? Super confused about this..
70c10guy is offline   Reply With Quote
Old 03-25-2017, 06:53 PM   #2
gmachinz
Re: 4 high AND headlight relay mod!
The Baron cat you're referring to has indeed appeared to vacate all things wiring related but if you need a 4-HI HD relay kit, I build plug n play harness kits. My kits only require the use of 2 relays instead of three and they have 4-HI built in. Relays are 40A sealed Hella and wiring is j1128 spec too. If you want/need more info PM me for details.
Specializing in building electrical harnesses and cooling systems
HARNESSWORX
"An army may march great distances without distress, if it marches through country where the enemy is not."
-Sun Tzu: The Art of War
gmachinz is offline   Reply With Quote
Old 03-25-2017, 07:01 PM   #3
gmachinz
First pic shows one of my 86-older style headlight plugin play relay kits, the second one is one of my 88-98 headlight plug n play kits-for reference. I have a lot of options on harnesses from 1960's and up...some people want a full lighting harness, others want a delay off headlight option, etc.
HARNESSWORX
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
