Old 04-20-2018, 03:07 PM   #1
69BUCKET
3 wire hook up
Curious as to where you guys are splicing into to connect wires from ls harness into truck harness....anyone care to give up some knowledge of best place and which wires they spliced into?
69BUCKET is offline   Reply With Quote
Old 04-20-2018, 05:09 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 3 wire hook up
what you need is switch on power....constant power...and grounds...
for switch on power I used the big switch on hot wire going to my hei...for constant hot I wired into the junction terminal on the firewall...grounds are self explaining ..but you do need to have ground to engine to body to frame....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-21-2018, 10:10 AM   #3
69BUCKET
Re: 3 wire hook up
For switch on power i used the big switch on hot wire going to my hei...for constant hot i wired into the junction terminal on the firewall...grounds are self explaining ..but you do need to have ground to engine to body to frame....
my truck didn't have an engine in it...so i guess i am asking more specifically which wire is the switch on power wire at the fire wall? Constant i have...and 3rd wire is for fuel pump which is hooked up....have new ground straps as well.
Old 04-21-2018, 02:38 PM   #4
mongocanfly
Re: 3 wire hook up
if the original trucks wiring is still there the should be a wire coming thru the firewall that went to the distributor. ..looks like a 10g wire...i cant remember the color but i think its red or pink....that should be a switch on wire...you can verify it with a volt meter...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-21-2018, 05:50 PM   #5
69BUCKET
Re: 3 wire hook up
Duh...i had it hidden in the loom i redid...thank you sir!
