05-08-2012, 08:54 PM | #1 |
2000 gmc jimmy help!!!!!!
I'm usually on the 67-72 side but my gfs jimmy died out the other day and I can't keep it running every now and then it will fire up for a few seconds and die, I'm getting fuel to the rail changed the fuel filter and mass airflow sensor cleaned every plug and sensor I could without pulling too much apart any ideas? It just died out going down the rd not a pop not a sputter just died.
Posted via Mobile Device |
05-09-2012, 09:41 PM | #2 |
laying low
Re: 2000 gmc jimmy help!!!!!!
Check rhe fuel pressure 1st.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
05-09-2012, 11:28 PM | #3 |
how many miles? if you have never done a fuel pump on it, it may be that time.
06-15-2012, 08:43 PM | #4 |
Anyone know the expected fuel pressure? I have the same car and have to use starter fluid to get it to start. I hot wired the relay to keep the pump going with the motor off and the pressure is a hair under 50 psi.
