Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 12-06-2016, 08:03 PM   #1
Bucket of bolts
Winter project replace inner outer rocker questions
Looking for advice, when I remove door is it best to leave hing on door or truck ?
Does the fender have to come off for this procedure?
After install and "tacked"/spot/ welded what adhesive do you run along top sill ? There is something on there now running the length of the entire rocker and can't figure out what it is. That's all for now Thanks ,
Bucket of bolts is offline   Reply With Quote
Old 12-06-2016, 10:25 PM   #2
hugger6933
Re: Winter project replace inner outer rocker questions
Yes you need to take off the fender. Because when you do inners you most likely will end up with the footwell and the A and B pillars needing changed as well. 99 times out of a 100 the parts listed will need to be on the list if inners are included. I think the "cab kit" is the best deal for rust repair add in a pair of foot well panels[ I have talked to the company and asked why they didn't include them they just don't know]and it should take care of most of the rust needs for the "normal' truck.
I take the hinge loose at the cowl then when I'm fitting it stick the door up on the latch to start the hinges.
Now I've done two of these recently, and it is labor intensive but it will make a huge difference in the cab once you have that done you come over a huge hump to getting that truck going your way.
hugger6933 is offline   Reply With Quote
Old 01-23-2018, 10:18 PM   #3
66C10LB
How did you make out with those rockers, bucketofbolts? BTW. I am not far from you...over by Mission Hill Winery.
66C10LB is offline   Reply With Quote
Old 01-24-2018, 08:37 PM   #4
goatless
goatless's Avatar
When I do this job, I'll first be refreshing up by watching Gibson63's videos: https://www.youtube.com/user/1gibsonl4
1964 C10 LWB->SWB, 283->454, SM420->200-4R
MECHANIC: "ME"
goatless is offline   Reply With Quote
Old 01-24-2018, 11:23 PM   #5
66C10LB
Ya, Goatless.....I have enjoyed all of the Gibsons63 vids as well and have found them helpful.
Old 01-25-2018, 06:22 PM   #6
Bucket of bolts
Truck has taken back seat to home renos,
First time I've parked her outside in winter ,garage being used as Reno work shop
I've done a lot of investigation on this site and you tube,got the parts,get after it as soon as garage is freed up.
BTW just on the other side of Mt Boucherie from you
Living in West Bank now
