12-23-2017, 05:37 PM | #1 |
Electrical , where does these wires go
Good Afternoon and Happy Holidays to all
ive got a small bundle of wires coming out of firewall right to upper right of factory square plug, i got in a hurry taking doghouse off and did not label, these dont show on the wiring schematic unless im looking at it wrong i have looked through forum and might be TCS wiring, again dont know red wire(looks pink) ,black and white wire, green and black/white wire has a blue wire all together attached to it(looks like an alternator plug)and a brown wire that loops up to the tray and goes into a rectangular clip its hooked up other wires are not if it is TCS, do i need to hookup or just tie together and leave alone Any help appreciated Thank You
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
12-23-2017, 09:48 PM | #2 |
Re: Electrical , where does these wires go
Look above the fuse block on the inside of the firewall. The big red wire probably goes to a relay that looks like the horn relay. If that's the case, it's the TCS relay and you really don't need to do anything with it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-24-2017, 03:01 AM | #3 |
3rd pic down is for the brake. Use the schematics in the electrical section. Some of that looks not stock to our trucks.
12-24-2017, 08:58 AM | #4 |
Thank You for your responses, the 3rd picture does show a connector that looks like the brake connector but its not, its coming off the engine wiring block harness and hooked up
12-24-2017, 03:53 PM | #5 |
Thank You Truckster
it is hooked up to a small box that looks like a horn relay, it was already disconnected from power, i coiled up the wires and wire tied them up kind of odd i would have the tcs system on my truck, its a factory 4 speed, i thought the tcs was only for automatics Thanks
