Old 10-07-2015, 08:26 PM   #51
Blown06
Blown06's Avatar
Re: My 71 custom10 deluxe
Looks real good.
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 10-07-2015, 08:32 PM   #52
brian1971
brian1971's Avatar
Thanks Jarrod
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
Old 10-08-2015, 12:17 PM   #53
Stuntman
Lovin' it Brian. Can't wait to see her done.
Stuntman is offline   Reply With Quote
Old 10-08-2015, 01:10 PM   #54
Smoothride
wow thats nice
Smoothride is offline   Reply With Quote
Old 10-08-2015, 11:53 PM   #55
brian1971
brian1971's Avatar
Thanks Stuntman and Smoothride,Lowering it a few more inches from 3/5 to 5.5/7 made a huge difference in the look.
Old 10-09-2015, 10:22 PM   #56
Security guy
Security guy's Avatar
Wow, that color really pops! I like it!
Security guy is offline   Reply With Quote
Old 10-24-2015, 12:21 AM   #57
litew8
litew8's Avatar
Is that an MB7100/MB7200 MAC toolbox from the 80's sitting back there? Nice truck btw
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 10-24-2015, 12:11 PM   #58
redbaron
redbaron's Avatar
You truck is looking very nice. Like the two tone paint
Mike
1972 C10 Cheyenne SWB Black Supercharged Project
1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175
1969 Camaro Protouring LS7 T-56 Project
redbaron is offline   Reply With Quote
Old 10-26-2015, 10:58 PM   #59
brian1971
brian1971's Avatar
Thanks Securityguy,Redbaron and Litew8 been working on it a lot lately.Litew8 yeah those are older Mac toolboxes from the 80's was given to me by one of the boats I do work for.
Installed the radiator this weekend it's an aluminum 3 core and radiator support from board member Joeelutz(Hotroddynamics).
Installed two 12 inch Zirgo electric fans in shroud.
Old 06-30-2017, 10:32 PM   #60
brian1971
brian1971's Avatar
Been awhile since I posted to thread,I pulled out procharged efi sbc and started to install a 6.2 ls motor.Has BTR stage 4 LS3 cam kit along with 4l85e w/3600 stall from a 2007 HD3500 express van.Parts used for swap are StreetRays adapter plates w/gbody clamshells and 1985 3500 pickup frame stands.Exhaust is TruRam stainless manifolds.I will be running Holley Dominator efi and oil pan is from a 2004 CTS-V.
Also accessory drive will be Holley along with LS3 water pump.
Old 06-30-2017, 10:35 PM   #61
brian1971
brian1971's Avatar
More pics
Old 07-18-2017, 09:55 PM   #62
brian1971
brian1971's Avatar
Installed 2006+up police crown vic aluminum driveshaft needed it shortened 1 1/4".These driveshafts take the big 1350 u-joints.Also started to install Wilwood master cylinder.Mounted up Holley accessory drive and installed Lokar shift linkage for the 4L80E.Got a lot done this week put in a few late nights on truck.
Old 07-18-2017, 10:01 PM   #63
brian1971
brian1971's Avatar
More pictures and also installed 2006-11 Honda Civic 2dr door weatherstripping fits real nice didn't even need to trim gaskets.
Old 07-19-2017, 12:07 AM   #64
boynton
boynton's Avatar
Good choice on the ls...you'll never build anything else...except maybe a monster BBC. They just sound too good.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 07-19-2017, 01:29 AM   #65
uxdesigner
Active Member
Really nice and tidy power steering lines. Custom? Part numbers? I really like the frame rail straps, nice work!
uxdesigner is offline   Reply With Quote
Old 07-19-2017, 10:41 PM   #66
brian1971
brian1971's Avatar
Thanks Boynton and uxdesigner.
The power steering lines are factory with a swedgelok adapter to hose and a 6an 90 on end.Then on Corvette power steering pump i just used a adapter to 6an fitting.The only thing with this setup is you have to use bigger power steering pulley that came on the 97-98 models not the open face one that came on later c5 and c6's or the 6an adapter on pump would hit pulley.
Old 07-23-2017, 10:22 PM   #67
brian1971
brian1971's Avatar
Installed the Holley R4 compressor brackets over the weekend.Ended up using a 6pk970 belt.
Old 07-24-2017, 01:04 AM   #68
rustytruck50
rustytruck50's Avatar
Nice, Nice truck!! Like the direction you're going! Keeping an eye on this one!!
'72 C10 Highlander "Raymond"
rustytruck50 is offline   Reply With Quote
Old 08-09-2017, 11:28 AM   #69
knomadd
knomadd's Avatar
I like the swap you're doing. Keep posting pictures, we all love seeing pictures of what you're working on.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-09-2017, 10:18 PM   #70
brian1971
brian1971's Avatar
Thanks Rustytruck50 bad Knomadd for the encouragement.I'll keep posting up pics been moving along pretty good lately.Been a long project but also have a 56 f100 I've been getting back on the road.
Brian
Old 08-09-2017, 10:26 PM   #71
brian1971
brian1971's Avatar
Finished up running fuel lines and regulator for second time.I had already did this before for procgarged sbc.I also mounted transmission cooler underneath truck below passenger seat.Still don't know what im going to do for tranny lines yet.Oh I got brakes working again stops on its own first time in four years !!
Old 08-09-2017, 10:28 PM   #72
brian1971
brian1971's Avatar
More transmission cooler pics
Old 08-10-2017, 12:12 AM   #73
brian1971
brian1971's Avatar
Installed this battery box a few months ago.I mounted it on passenger frame rail in front of rear tire.It's a auxiliary box from early 2000's Ford E350 diesel.Had it powder coated black.Used a Odyssey battery.Was hard to get a real good pic with truck on ground.
Old 08-13-2017, 12:28 PM   #74
brian1971
brian1971's Avatar
Went buy the local Aeroquip store yesterday picked up some hydraulic crimp 3/8 jic 6an fittings and Eaton Aeroquip matchmate hose.It's a little overkill but won't have to worry about them again.I will go back Monday and have them crimp the ends on.
Old 09-04-2017, 08:16 PM   #75
DarkKnightWong
Do you have any more pictures of the Civic weather stripping ?
How do they fit at the bottom ?
DarkKnightWong is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
