Old 05-13-2013, 11:28 AM   #176
mcbassin
Still Learning
mcbassin's Avatar
Re: 67 gmc-project ball to the walls
very nice work on the door repairs, I know how tough it is to make those patches fit.
Old 06-11-2013, 01:03 PM   #177
mcc-bri
mcc-bri's Avatar
Back in town and trying to get some work do e on the truck. Picked up a tailgate yesterday and threw it on this morning. Will have a new cowl hood next time I'm home.
My 67 GMC Balls to the walls build- http://67-72chevytrucks.com/vboard/s...d.php?t=268195
mcc-bri is offline   Reply With Quote
Old 06-12-2013, 12:21 AM   #178
Hardesty454
Hardesty454's Avatar
Its amazing how you can tell your skill level has GREATLY increased from the beginning of this build until now. Youre doing a killer job on this build and your body work look fantastic. Keep up the progress and keep us updated!
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 06-13-2013, 02:41 PM   #179
mcc-bri
mcc-bri's Avatar
Haha, I have noticed the same thing. Especially now that I have had to re do some of my original work but considering I was 15 when I started and am now 23 you would hope I would learn a few things over the years.
Had to do a little heating and shrinking of the metal to get things nice and flat again and it went quite well considering how hard it is to get a dolly in behind the panel I'm working on. This pic is of me straightening and pounding out the dents after the shrinking.
Old 03-21-2017, 11:38 PM   #180
mcc-bri
mcc-bri's Avatar
Wow, it has been awhile! After 2 years out of town, coming home and buying a house and then over 2 years of renovations its time to work on the truck again.
Im getting married this September and the Boss says she wants the truck ready for some wedding pictures so im back in the garage finally.
Since its still cold here in Manitoba and im tight on space with my snowmobiles in the garage i decided to start with tearing down my engine to see if my timing gear issue caused me any more greif. All tore down and from what i can tell it looks good but glad i tore it down since i found 2 chunks of metal off my timing cover in the pan.
Will start assembly next week hopefully and then some fresh paint since it looked like crap.
Old 04-03-2017, 11:01 PM   #181
mcc-bri
mcc-bri's Avatar
So much for cleaning and going back together.
After closer inspection i burnt 2 cam lobes so throw that in the garbage and 2 of my rod bearings had funny wear on the outside of the crank. close look at the crank and you can see that the taper isnt right and it has funny tooling marks so its a boat anchor now. Should have never gone together in the first place with the crank that way.
Anyways i picked up a 66 327 with a good crank sunday so just some final cleaning and buy or track down some .060 pistons and then off to the machine shop.
In the mean time i started stripping my firewall.
Old 05-11-2017, 12:42 AM   #182
mcc-bri
mcc-bri's Avatar
Well making a little progress. Got the box of the truck 2 weekends ago and this past weekend got my heads all back together.
This weekend will be firewall stripping and im running to the boarder to pick up all my engine parts and then its off to the machine shop.
Old 05-11-2017, 09:53 AM   #183
raggedjim
raggedjim's Avatar
Glad you are back on it. I have some long term projects I need to get wrapped up (one day!)
Good luck, Rg
Roger
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 05-12-2017, 04:16 AM   #184
mcc-bri
mcc-bri's Avatar
Good luck, Rg
Thanks, this time its till the end!
This week i have been mocking up my new rear gas tank and it has been a bit of a head scratcher since i bought it around 4 years ago and don't remember who from.
Got a plan to make it work now!
Also i don't work tomorrow so have been pulling stuff off the firewall and stripping paint tonight (it is after 3am now). About 80% done with that and on the fence about body working the firewall. See how far i get this weekend.
Old 05-15-2017, 10:47 PM   #185
mcc-bri
mcc-bri's Avatar
Well it was like Christmas morning on Saturday. drove down to the boarder and picked up all my engine parts. Dropped everything off at the machine shop tonight so hopefully get it back next week and start assembly.
Old 05-23-2017, 07:07 PM   #186
mcc-bri
mcc-bri's Avatar
Made a little progress this weekend.
Got my rear tank in after some head scratching and making up some brackets out of angle iron to hold it nice and tight.
Old 05-24-2017, 11:46 AM   #187
NewType72
NewType72's Avatar
Great work in the straps. Very tidy
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 06-16-2017, 06:06 PM   #188
mcc-bri
mcc-bri's Avatar
Haven't updated in awhile but still working away.
I have everything back from the machine shop so i can assemble the engine any time now but since it took a little longer then expected i started on body work so engine assemble is on hold till the cab is in paint so i can drop it in and assemble the driveline, exhaust and break it in.
Bodywork was going good and getting close to spraying some more high build on the cab until found some issues that i didn't take care of first time around.
Old 06-18-2017, 05:11 PM   #189
mcc-bri
mcc-bri's Avatar
Had a real productive day yesterday getting ready for another shot of high build. Even had my buddy mike (67seaten) come over and help out into the night.
Just a little sanding to finish up this week and fix up the cab corners 16 year old me welded in and will be spraying primer.
Old 07-11-2017, 11:11 PM   #190
mcc-bri
mcc-bri's Avatar
Haven't posted in awhile. Since last post i have continued to work on the back of the cab and it has been more involved then i first thought. In the body filler stage so hopefully im spraying high build by the end of the week.
Made the decision last week to pull the cab to make body work and paint easier. looking like a full blown body shop in here now!
Also made the decision and ordered up my bed wood today! went with ash.
Old 07-18-2017, 12:08 AM   #191
mcc-bri
mcc-bri's Avatar
Well it was a busy week and some long hours on the weekend with a 12 hour shift on sat and 15 hours sunday but the cab and front clip are in highbuild. Things are looking really good and the plan is to start blocking tomorrow.
Old 07-18-2017, 05:29 AM   #192
GR8-68
GR8-68's Avatar
Wow !! Great progress Brian the project is looking really good. You have done some really nice work
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Bed wood floors" For price requests, shipping quote or questions please email at: lgrant@dixoncabinetry.com
"Project 68"
"Project 72 Monte"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 07-20-2017, 04:28 PM   #193
mcc-bri
mcc-bri's Avatar
Thanks Larry, its finally coming together after almost 10 years.
Really looking forward to seeing that bed wood!
Old 07-24-2017, 05:34 AM   #194
GR8-68
GR8-68's Avatar
We are working on that for you now should ship out hopefully the end of this week beginning of next
Larry
"Project 68"
"Project 72 Monte"
paypal.me/ldgrant
Old 07-26-2017, 09:28 PM   #195
mcc-bri
mcc-bri's Avatar
Great, Looking forward to it!
Old 08-07-2017, 09:42 PM   #196
mcc-bri
mcc-bri's Avatar
Haven't been on here in awhile because i have been too busy working on the truck.
As of 4 pm today the cab and front clip are in paint! I was in the garage getting ready for my buddy to come over yesterday around 9 am cleaning out the place and prepping stuff. He showed up around 4 pm and after more prep work we were ready to spray around 10 pm last night.
Lets just say we got off to a rocky start that cost us a lot of time. We ended up spraying the last coat of clear at 4 pm this afternoon.
Really happy with how it turned out.
Also check out the filter and exhaust set up i made. It worked really well!
Old 08-08-2017, 05:11 AM   #197
builtbyKane
builtbyKane's Avatar
Color!!! What a milestone congratulations
builtbyKane is offline   Reply With Quote
Old 08-11-2017, 03:05 PM   #198
mcc-bri
mcc-bri's Avatar
Thanks, it was great to finally see some color after all the hours of sanding.
Old 08-11-2017, 03:09 PM   #199
mcc-bri
mcc-bri's Avatar
Slowly going back together this week and so far my panel gaps are working out.
Also picked up my ash bedwood this week that i ordered from GR8-68. Anyone looking for wood should check out his stuff. Great prices and i cant say enough about the customer service!
Old 10-27-2017, 11:55 PM   #200
mcc-bri
mcc-bri's Avatar
well holly lick boys, i haven't been on here in a long time but that dosnt mean i haven't been working on the green machine! ill post up what happened in my absence in a little bit. it took everything i had which meant about 3 hours of sleep a night but the truck made it. We finished the first real test drive around 10 pm the night before my wedding.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
