Old 08-03-2017, 03:53 PM   #26
BFD305
Re: CPP Disc Conversion - Good and Bad
Thanks for the write up. Are you running the 12" rotors from CPP? I am getting ready to order, but don't want to switch wheels.
I have about 14.5" across. Do you know the inner diameter on your new rims?
BFD305 is offline   Reply With Quote
Old 08-05-2017, 11:40 AM   #27
maydaymike
maydaymike's Avatar
Originally Posted by metalprelude View Post
I determined that I had my brake lines reversed. I flipped them over and was able to bleed the calipers. The pressure is still not as firm as I'd like but, it's better.
In regard to the rims, I've decided to buy the Cragar rims shown below as they'll fit my Coker white walls at 15x7 and at $60, I can't beat it.
https://www.summitracing.com/parts/crr-69576037
Anyone have experience with these?
I'm running those Cragar wheels on my '66. 15x6 front and 15x8 rear. Cant beat them for the price.
maydaymike is offline   Reply With Quote
Old 08-11-2017, 11:26 PM   #28
metalprelude
What size bore of clutch MC is needed for the original hydraulic clutch?
Looking at this setup:
https://www.performanceonline.com/WI...YLINDER-19753/
metalprelude is offline   Reply With Quote
Old 08-12-2017, 12:45 AM   #29
Captainfab
60-66 Nut
You need a 1" bore clutch master. That is what I supply in my kit for those with the '60-'62's that are keeping the original clutch slave cylinder.
http://www.67-72chevytrucks.com/vboa...d.php?t=362375
Old 08-13-2017, 11:57 AM   #30
metalprelude
Your brackets seem to be really popular in this forum and others. Using your kit to complete the power brake conversion on my 61, I'd need a booster, brake MC, and some split brake lines, right?
Old 08-13-2017, 11:15 PM   #31
Captainfab
60-66 Nut
That and if you are changing to front discs, you will need a disc/drum proportioning valve also.
Old 08-13-2017, 11:49 PM   #32
rvrfoot
You can have it here or put it on your frame. the proportioning valve.Name:  DSCN0824.jpg
rvrfoot is offline   Reply With Quote
Old 08-14-2017, 12:02 AM   #33
sirJim
62 suburban
So, regardless if I go power brakes or not, a dual reservoir MC is the safest approach but, I have to install a separate MC for the clutch?
Also, if I go to a salvage yard, what are my best options for donors?
I went with captainfabs setup and works great!
sirJim is offline   Reply With Quote
Old 08-29-2017, 04:19 PM   #34
TheBrewery
Junior Member
TheBrewery's Avatar
I am about to tackle this on my '60, please post some photos when your done so I can learn from your hard work
TheBrewery is offline   Reply With Quote
#brakes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
