Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 01-24-2020, 02:13 AM   #1
stomper
Junior Member
stomper's Avatar
How to gently remove a color change
This truck got a blue respray by the original owner sometime before 1991. Inside and out over the beautiful vermillion red exterior and fawn interior. It looks pretty straight with original sheet metal. I see the original red everywhere the blue has flaked off. Bondo only to fill the dimpled trim holes.
Has anyone had success removing something like this? I've had success on another car with the aircraft stripper I got from my local auto parts house. However on this truck, the blue is so well bonded to the red. Ive tried some spots under the cowl and inside the bed. Anything I use that dissolves the blue also softens the red. Ideas other than wet sanding?
"I was patina when patina wasn't cool."
'83 K30 Silverado SRW Factory 454 / T400 / NP205 loaded
'67 C10 SWB 283 / 3spd / radio
stomper is offline   Reply With Quote
Old 01-24-2020, 10:22 AM   #2
stomper
Junior Member
stomper's Avatar
Re: How to gently remove a color change
I also tried these two products. Both just melt thru both colors.
Old 01-24-2020, 11:05 AM   #3
stomper
Junior Member
stomper's Avatar
I'm reading maybe EasyOff over cleaner will work. Gonna a try that next.
Old 01-24-2020, 04:54 PM   #4
LS short box
I've stripped a number cars with air craft stripper. Typically takes at least two applications to get all of the paint off and then another to remove the primer down to bare metal.
Keep it away from seam and cracks. It can leak back out after painting. I do the big panels with stripper and then sand blast all the edges.
Be careful with air craft stripper, it's nasty stuff. Full face shield, heavy rubber gloves and good ventilation if you doing it inside.
Old 01-24-2020, 05:01 PM   #5
mongocanfly
Unknown thing is what's under the blue?..is the red worth saving?
Mongo...aka Greg
2013 GMC Z71..daily driver
Old 01-24-2020, 10:25 PM   #6
LS short box
The red looks like primer to me. If you use any type of solvent it will soak into layers of paint or primer below it. That's not good.
Old 01-25-2020, 05:13 AM   #7
stomper
Junior Member
stomper's Avatar
Maybe I wasn't clear. I want to take off just the blue.
Old 01-25-2020, 05:15 AM   #8
stomper
Junior Member
stomper's Avatar
I'm fairly certain it's not in any worse shape than the blue
Old 01-25-2020, 05:16 AM   #9
stomper
Junior Member
stomper's Avatar
It looks like primer to some in person but it's the original vermillion red.
Old 01-25-2020, 09:19 AM   #10
nsb29
nsb29's Avatar
There is no way youíre going to strip the blue and not remove the paint underneath even sanding your going to have sand through in places
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 01-28-2020, 04:10 PM   #11
Marty68
Marty68's Avatar
^^ true statement^^
Truck goals... 0-70 then 70-0 safely
Marty68 is offline   Reply With Quote
Old 01-28-2020, 04:22 PM   #12
stomper
Junior Member
stomper's Avatar
I successfully removed all the body color from the underside of the hood and hinges on this 61 Chevy. Was it because the repaint was a different type than the original? Forgive me but I never attempted to learn all the chemical wizardy. I don't have the patience for body and paint work.
Old 01-29-2020, 09:07 AM   #13
nsb29
nsb29's Avatar
Not knowing what you used on the hood itís hard to say why it took the color off and left the black but more than likely the black was OEM and more resistant to the chemicals you used
Old 01-29-2020, 12:36 PM   #14
stomper
Junior Member
stomper's Avatar
I used the aircraft stripper on the hood. I was hoping that the original red paint on the truck would also be more resistant than the blue, as was the case on the Bel Air. However, this is not the case. I'm searching for a product that would break down the blue but not the red, as was the case on the turquoise and black on the car hood.
Old 01-29-2020, 09:09 PM   #15
goatless
goatless's Avatar
LOL, no, you were clear
1964 C10 LWB
MECHANIC: "ME"
goatless is offline   Reply With Quote
Old 02-08-2020, 12:57 PM   #16
toolboxchev
Hey Stomper, that would be a very difficult task to accomplish. There is no specialty products that address this. Paint composition has changed dramatically through the decades and now were heading into new territory with the Low VOC and waterborne stuff. It gets quite complex.
I am a beginner, but after doing some research I ended up listening to some very experienced people on this website and decided to tackle some areas of rust repair on my truck.
Check this product line out: https://www.southernpolyurethanes.com/
Barry the owner will speak to anyone wanting to do his own paint job. He is not arrogant, and has a high quality product with consistency. He does his own QA before it leaves his plant. Competes extremely well with PPG, Dupont and puts some shame on them.
His Epoxies for primer and hands down easy to work with, they can be brushed also for spot repair. That stuff sticks to metal if you follow his instructions to a T. Its a fun thing to do and the costs are affordable comparatively to the high end.
Something fun to get into and with patience you can end up with a dynamite job.
toolboxchev is offline   Reply With Quote
Old 02-09-2020, 01:52 AM   #17
franken
Probably crazy expensive and may not work a bit but maybe try some B12 Chemtool rub.
Old 02-13-2020, 07:04 PM   #18
Skymortar
Junior Member
You cannot remove the blue without ruining the red.
Skymortar is offline   Reply With Quote
Old 02-15-2020, 02:21 PM   #19
pwdcougar
pwdcougar's Avatar
And I'm here to do my usual rant every time someone mentions aircraft stripper. This is dangerous stuff. Breathing the vapors and getting on you skin messes up your liver. No over the counter gloves will protect you.
Ask me how I know.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1968 2WD GMC Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 02-16-2020, 03:21 PM   #20
67swb72klb
67swb72klb's Avatar
Wet sanding is you best bet labor intense though
Your results depends on what bodywork was done for the repaint..
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 02-25-2020, 08:32 PM   #21
rod1701
rod1701's Avatar
My truck looks as if it came from the factory blue. Had another blue repaint that was slightly different. Then topped off with white.
Paint remover with Methylene-Chloride will work but getting harder to find due to toxicity and EPA concerns. Take it from a guy living in LA who used to use it for everything.
Still going to take it down to metal at least in spots. No way to get rid of the blue only.
Take it to the soda/media blaster, strip it to metal and rebuild it OR straighten what you can, clean up details like overspray, take 320 grit to it until it looks like red underneath is paint worn down to primer. Matte clear it and enjoy the heck out of it. Then you won't have to fret when you get a chip, nick, or ding.
1979 C-10 LWB
rod1701 is offline   Reply With Quote
Old 02-26-2020, 10:51 AM   #22
stomper
Junior Member
stomper's Avatar
I like the 320 grit option - or try some different sanding methods and see what works best. This will probably take me years, doing sections occasionally.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
