Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 03-11-2020, 05:36 PM   #1
superhondaz50
superhondaz50's Avatar
Check my fan wiring
Using dual fans from an F150. With a 180* trigger both fans run in a series at half rpm. At 195* the relays trigger and run each individually at full speed.
superhondaz50 is offline   Reply With Quote
Old 03-11-2020, 09:12 PM   #2
lutronjim
Re: Check my fan wiring
Looks like it would work if 2 fans in series would run 1/2 speed. Never tried it.
lutronjim is offline   Reply With Quote
Old 03-12-2020, 08:08 AM   #3
superhondaz50
Alright, the half speed should work I think since as a series the voltage will be split between the two. The only thing I'm concerned with, is I don't know how many amps these draw on startup, hoping they won't pop the 30A breaker.
