10-20-2014, 11:10 PM | #1 |
Scotts Hotrods Crossmember Install
So after going between Scotts and Porterbuilt I found a really good deal on a scotts so here we go.....
10-20-2014, 11:16 PM | #2 |
Re: Scotts Hotrods Crossmember Install
First is to remove your old crossmember. I found it easier to support the frame rails under the cab. I left the wheels on the vehicle. I removed the four bolts that hold the sides of the member on. Then used a jack to support the crossmember.
10-20-2014, 11:22 PM | #3 |
I found it way easier to hit the six bolts the mount the member to the lower frame with pb blaster and then use an impact to loosen the 6 bolts. After the 6 bolts are loose use a cut of wheel and cut them off. Then lower the whole thing out and put ti to the side.
10-20-2014, 11:24 PM | #4 |
I feel that when installing a 4000 dollar crossmemebr you should clean the inside and outside of all mounting points.
10-20-2014, 11:27 PM | #5 |
spent more time cleaning than it took to drop the oldmember
10-20-2014, 11:33 PM | #6 |
I have the member already assembled in my family/ all my new parts room. Being that i bought it used I got it assembled but im pretty sure it comes this way. I say it was used but its never seen anything but mock up and then the whole project was sold.
10-20-2014, 11:39 PM | #7 |
Take your new Scotts and raise upwards to your clean frame and install 2 bolts/nuts and also two bolts that go into the side of the crossmember.
10-20-2014, 11:43 PM | #8 |
Then you take your inner frame brackets and bolt in the 6 upper and lower bolts.
10-20-2014, 11:47 PM | #9 |
Then remove your steering column. And mount your wheels and tires.
10-20-2014, 11:56 PM | #10 |
And then let your results show
10-20-2014, 11:59 PM | #11 |
better final pictures when its day light. Now a few things that make this easier was having the front clip off and engine already out. It took a a day to put in but easily done in a weekend if you also had to remove the clip and engine.
10-21-2014, 06:44 AM | #12 |
great thread!! I'm researching an IFS for my 79 Blazer, and Scotts is being considered. I'm curious, where is the difference between the 67-72 and 73-91 frames? You were lucky to find a used (not really) one!! Good luck with the build!
"Its never too late to have a happy childhood." 70 Roadrunner,.. 79 Blazer, ..85 Harley bobber,.. 97 GMC Suburban Diesel,.. 99 Sierra, ..06 Ducati Monster Dark, ..07 Silverado ,.. 11 Audi A4 |
10-21-2014, 03:52 PM | #13 |
Looks good in there! Glad it all worked out for you! I can't wait till mine is a rolling chassis at least again! Mine looks bare for now! Lol
49 Chevy - currently under construction being bagged and hunting for a LS drivetrain!!! 09 - Harley nighttrain on air ride! |
10-21-2014, 04:22 PM | #14 | |
I can tell you a few things.... my truck is a 64 and the scotts crosmember says 67-72 on it. I know that many people use 73-87 c10 parts on 64-72 trucks. If you look at your current crossmember it will have a few more bolts than mine does (think its one per side). Now as for the rear 63-72 are all most the same but from side to side your holes in the frame may be a little different. My bolt in KP six link is going to take me drilling a few extra holes that a 71 has that my 64 doesnt. Look for a Install for the 6 link next weekend. |
10-21-2014, 04:27 PM | #15 |
Im going to cry when i have to take mine all apart for blast and paint/ powder coat. btw call Tim at Ekstensive for your wheels damn good guy- 281-442-1050
10-21-2014, 05:18 PM | #16 |
Thanks, Zack...post lots of pics!!
10-21-2014, 10:28 PM | #17 |
I didnt get home before dark but tried taking pics with no luck..... itl prob be a few days before i get back home because of work.
11-03-2014, 08:47 PM | #18 |
couple pics
11-03-2014, 08:50 PM | #19 |
with a few extra stuff bolted on.... including a kp 6 link
11-03-2014, 09:28 PM | #20 |
Killer
GOD BLESS AMERICA! |
11-03-2014, 11:40 PM | #21 |
thanks..... going to put the watts link in next week or so
11-04-2014, 12:34 AM | #22 |
Nice work. Justin and the guys over there know how to build some sweet stuff. Check this thread out I did when I got my super slam
http://67-72chevytrucks.com/vboard/s...d.php?t=497124
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
11-04-2014, 01:35 AM | #23 |
your burb looks great, Justin was a great help when plannning the build! I just got really lucky and found one that had just been mocked up but never on the road used. Ive got a 63 burb im going to buy once i get a little more room. itl be on the ground also!
11-04-2014, 01:37 AM | #24 | |
11-04-2014, 09:31 AM | #25 |
I'm not quite sure. I've had a few renderings done so let's see what route I end up going.
