06-18-2017, 10:51 PM | #1 |
Engine Removal Mounting Points
Just wondering where to hook cherry picker chains to without heads or intake on engine....Want to pull engine and trans as one unit...
06-18-2017, 10:53 PM | #2 |
Re: Engine Removal Mounting Points
Bolt some lift brackets to the block where the head bolts go
06-18-2017, 10:58 PM | #3 |
06-18-2017, 11:15 PM | #4 |
60-66 Nut
I would remove one of the bellhousing bolts, replace it with a longer grade 8 bolt and a washer with it thru one link of your chain. I would do the same with one of the water pump bolts. Run your chain at a diagonal. Or if you have 2 chains, make an X with them. Most of the weight is going to be at the rear.
06-18-2017, 11:37 PM | #5 | |
06-19-2017, 11:06 AM | #6 |
06-20-2017, 12:23 AM | #7 |
60-66 Nut
Then simply bolt those brackets to the block by using some 7/16"-14 bolts with washers into 4 of the head bolt holes.
06-20-2017, 08:28 AM | #8 |
06-20-2017, 10:26 AM | #9 |
Lift brackets...ike the ones at the end of the chains on the load leveler
