Old 10-12-2017, 08:31 PM   #1
jwn1975
1970 auto shifter broke!
Guys,
super frustrated here. A new to me truck I got running after years of sitting. I drove it at my shop today and putting it in gear, It was difficult to move the shift lever towards me to drop it in gear. After maiden voyage, I horsed the lever to put it in park and "pop" now she moves free (doing nothing) and Im pissed at myself. What did I break and how easy it is to fix? I know I should have lubed the linkage at the end of the shaft but was super excited to drive it.. Thanks
jwn1975 is offline   Reply With Quote
Old 10-12-2017, 09:47 PM   #2
HO455
HO455's Avatar
Re: 1970 auto shifter broke!
Here is a thread with a ton of information on columns. My Burban did a similar thing and it was the clamp on the rod to the tranny sliding on the rod
http://67-72chevytrucks.com/vboard/s...d.php?t=720752
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
Old 10-13-2017, 04:22 AM   #3
Ironangel
Ironangel's Avatar
Originally Posted by jwn1975 View Post
Guys,
You may have broken or dislodged/disengaged the ball pivot on the end of the shifter handle. Drive the pin out of the handle to release it from the shift collar. The end should look like this, ...If the ball pivot is broken you have two choices, replace the shifter handle, or...You can save the expense and do what I did...I drilled and tapped the end of my shifter handle for a 1/4"- 20 grade-5 bolt, smear some JB-Weld or red Loctite on the bolt and thread it into the handle, cut it to the proper length (3/4" I think?) and file it in to shape with a ball on the end. Worked like a charm for me but I was able to use the shifter out of my other truck as a pattern. You should be able to use the broken piece as a pattern...
Michael Hill, "Ghostrider"
1980 KZ-1000 ST-MKII, "Baby Doll"
72 Chevy C/10 SS-396 w/Comp Cam=268H, Closed Chamber 290 heads, Stage-4 Power Pack (Eagle Red's) 350THM, Beefed up 12-Bolt, Eaton 4:56 Posi, (Diesel Killer) Street Rod LWB "Nasty Sally"
72 Chevy C/10 Rebuilt 350 w/Voodoo-10120701 Cam, Stage-4 350THM, Beefed up 12-Bolt 3:73 Eaton Posi, LWB Wood Bed, (Daily driver, work horse) "Belle"
https://www.facebook.com/michael.hill.12979
https://www.facebook.com/kz1000rider/
Ironangel is offline   Reply With Quote
Old 10-13-2017, 01:52 PM   #4
cleszkie
cleszkie's Avatar
Back when I still had an auto tranny (TH350), my column shifter became harder and harder to move. One day I forced it and the ball stud broke off the end. I bought a new lever and installed it, but it didn't solve the hard shifting issue. Turns out, the old grease inside the steering column had just hardened up to the point that it was causing a lot of drag on the internal column linkage. I simply sprayed a bunch of my favorite penetrating oil down the column, let it soak, hit it again, cleaned up the excess oil that ran out the other end, installed new shift lever and cycled it through the gears a couple of times. Totally freed up the internal column linkage and it shifted into gear a smooth as silk.
cleszkie is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
