Old 11-13-2018, 09:51 PM   #1
enge909
87 C10 6/8 static drop
Has anyone one done a rear flip kit with 2” drop shackles? Is it better to go with flip kit and 2” spring hanger? I went with the shackles but need to cut rear bed support and the pinion angle is off. Debating about if the spring hanger is a better route.
enge909 is offline   Reply With Quote
Old 11-14-2018, 12:28 AM   #2
mongocanfly
mongocanfly's Avatar
Re: 87 C10 6/8 static drop
Welcome....
You get that low and I think you'll have to do a c-notch
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-14-2018, 07:38 PM   #3
SCOTI
SCOTI's Avatar
The need for notching the bed support will depend on the spring length. The longer 56" HD springs don't require notching to clear a drop shackle. The shorter 52" lighter duty springs will require clearance.
As for which is better.... That's prob subjective. Personally, the rear shackle is less work.
Although you didn't ask, as Mongocanfly stated c-notching will be required. That being said, you'll still likely bottom out occasionally as the rear differential will hit the bed floor. This is a pic of my old 74 that was dropped w/a flip + Belltech shackles:
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-15-2018, 12:56 AM   #4
Project86
i dont have drop shackles, but i do have a flip kit on my 86 hotrod.
i didnt do a C notch and i dont have any issues bottoming out
Project86 is offline   Reply With Quote
Old 11-15-2018, 12:21 PM   #5
SCOTI
SCOTI's Avatar
Typically a flip-kit alone doesn't require c-notching. When combined w/additional method to drop it more, there will prob be issues.
Also, the total amount of drop from a "flip-kit" is dependent on the quantity of springs in the spring pack. The greater the quantity of leafs, the greater the drop amount.
I'm pretty sure the OP was inquiring about the bed cross-sill supports. Adding shackles to trucks w/52" leafs typically result in interference w/a rear cross sill.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
