Old 09-23-2018, 10:46 AM   #1
Curt - TN
55- 59 Front Coil Over Spring Rates (C4 Corvette)
I am building a 57 GMC and I had RRFRAMES.COM build me a chassis. His frame uses C4 suspension from an 88-96 Corvette and it uses the mono-leaf.
To get some additional adjust-ability I am considering doing the vansteel.com QA1 coil over conversion on the front but I have no idea what spring rate to get. I suspect it should be on the heavier sites of what was available in a C4 Corvette and that was 531 to 656 lbs.
For those who did coil overs on the front if your 55- 59 what spring rate did you end up going with and are you happy with it?
Curt
Brentwood TN
1950 Chevy 5 Window 3100 - Check out my Build Thread: http://67-72chevytrucks.com/vboard/showthread.php?t=724260
1957 GMC 100
Curt - TN is offline   Reply With Quote
