Old 07-26-2017, 01:42 AM   #51
MattyBs71
MattyBs71's Avatar
Re: 67-72 Suburban OE seats
Does anyone sell second or 3rd suburban bench new seat foam??? I'm not finding any out there online
MattyBs71 is offline   Reply With Quote
Old 07-26-2017, 11:10 AM   #52
vectorit
What?
vectorit's Avatar
When I did mine a couple years ago, myself and my upholstery shop could not find anyone making 2nd row size foam.
I haven't looked recently, but I'm betting there still isn't anyone making pre formed foam like the 1st row yet.
What I do know, is that the pre formed foam replacements are super expensive. So plan for sticker shock.
Chris
1968 K20 Suburban
vectorit is offline   Reply With Quote
Old 07-26-2017, 12:26 PM   #53
MattyBs71
MattyBs71's Avatar
I know foam is expensive.... LOL.... thank you for the info.
Old 08-07-2017, 04:58 PM   #54
MattyBs71
MattyBs71's Avatar
Who sells the full size 2nd row bench covers? They are about 58 inches long and I can't find anyone that sells them! I can find the 48 in long blazer/burb third seat but no full size second bench seat covers! First row bench won't work because they don't cover the backs of the seats.
Help! I feel like I have looked everywhere. LMC, Brothers, no name online shops.
Old 08-07-2017, 06:08 PM   #55
vectorit
What?
vectorit's Avatar
Pretty sure no one is making burb specific seat covers for the rear.
The 3rd bench is Blazer size, so shops get more business selling them to Blazer and burb people. But when it comes to burb only, it seems no one stocks them.
I had all of my seat covers made by a local shop, and I supplied all original style materials for the job.
Chris
1968 K20 Suburban
Old 09-19-2017, 06:53 PM   #56
bhahn70
bhahn70's Avatar
This thread is only for OE seats for 67-72 Suburbans.
There are often questions pertaining to type of benches, and what type of brackets and hold downs were used.
So I thought that this should be a sticky thread, and for reference only when it comes to the Original Equipment seating of the 67-72 Suburban.
This includes brackets, and upholstery that were Original to the 67-72 Chevrolet and GMC Suburbans.
Often FAQ's
Will a 1972 bench seat work in my 1967 Suburban - Yes
All 67-72 benches will interchange.
Are the brackets reproduced, who makes them? - At this time 02/2016 no one is making brackets.
Are the hold down brackets reproduced, who makes them? - Yes, these can be found from various vendors. But be sure to include Blazers in your search, since often times they are sold only as Blazer brackets.
Looking for 2nd and 3rd row. Found this. guy said it was second row but only 43.5 wide. Does anyone know what it's for. I have arm rest brackets so that's not an issue just trying to figure out what it's for being that short.
Thanx,Brian
bhahn70 is offline   Reply With Quote
Old 09-19-2017, 09:37 PM   #57
vectorit
What?
vectorit's Avatar
It has the short rear brackets, so I would think that this is a 2nd row bench.
Chris
1968 K20 Suburban
Old 09-19-2017, 09:45 PM   #58
bhahn70
bhahn70's Avatar
Yes that's what I thought my buddy measured the second row in the 72 highlander Burban I sold him and it measures 48" definitely factory. So I'm not sure why this seat is 4.5" shorter. Maybe I'll ask him to triple check the measurements. Thanx
Old 09-19-2017, 09:51 PM   #59
vectorit
What?
vectorit's Avatar
I don't recall the exact measurement of what I call the "short bench", but like my burb I have a short bench as a second row. This same bench fits just fine as a 3rd bench between the wheel wells, and could be converted to a 3rd bench if I set it up with 3rd bench brackets.
So what you may have here is just a 2nd row short bench. GM offered full length and short benches for the second row.
Chris
1968 K20 Suburban
Old 09-19-2017, 10:15 PM   #60
bhahn70
bhahn70's Avatar
Question Re: 67-72 Suburban OE seats
Yeah I have the full length in there now and my last one had the short that measured 48". Also everything I find on the second and third row says they are 48". I'm just wondering why this is so much shorter does anyone have a second row that is 43.5" longThe brackets tell me that it's 2nd row. Not to sound like a broken record but it's shorter than the short. Did another manufacturer use a similar setup. I'm a wacko I like stuff as it came from the factory and for that specific vehicle.
Thanx, Brian
Old 10-27-2017, 02:20 PM   #61
mrtoni
Can’t quite get my head around this. I have two blazer rear seats. These will fit as second and third row in my burb? Will either blazer bracket work or what do I need?
mrtoni is offline   Reply With Quote
Old 10-27-2017, 02:38 PM   #62
bhahn70
bhahn70's Avatar
2nd and third row brackets are different. I believe the blazer rear seat is the same as the suburban 3rd row seat But not sure. I do have a 3rd row at the shop I can take pics and give you specs on the 3rd row brackets Monday if nobody replies before then.
Old 10-27-2017, 02:43 PM   #63
RedRoad
RedRoad's Avatar
Seat measurments
RedRoad is offline   Reply With Quote
Old 01-24-2018, 04:52 PM   #64
mrtoni
So my burb has a full length 2nd row seat. 58 inches. No third row but I want to add one. I have two blazer benches both 50 inches. I believe looking at factory diagram that second and third row are both 50 inches. I probably can change full length mounts from second row onto shorter third row? Matt
Old 01-26-2018, 11:29 PM   #65
sirbourbon
sirbourbon's Avatar
In search of either bucket or front bench frame and brackets for my 70 suburban. Going to recover with new foam and vinyl, but I can't find the frames anywhere. Any suggestions? Help please!
sirbourbon is offline   Reply With Quote
Old 01-28-2018, 07:43 PM   #66
kbrown
I found a second row seat for a 1975 Blazer, The bolt holes in my 72 burb measure about 42 in. for the third row seat the blazer seat rear brackets measure 35 1/2. does anyone know if the brackets can be moved on the blazer seat or would I have to relocate the holes in mv 72.
Kevin
kbrown is offline   Reply With Quote
Old 01-28-2018, 08:52 PM   #67
richard2717
richard2717's Avatar
Matt
Yes, both blazer seats will fit in your burb for 2nd & 3rd row. The blazer seat is direct fit for the 3rd row in the burb. You will have to swap out the Blazer brackets for 2nd row burb brackets to use it as a second row. The 3rd row brackets are roughly 4" tall front and back while the 3nd row brackets are roughly 2" in rear and 7" in front to allow for the step down in the floor from the wood to metal section. I do have some nice 2nd row brackets if you want to do some swapping.
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis
https://paypal.me/6772GMtruckparts .... Please click on goods and services and not friends & family otherwise your address will not show
5 OUT OF 6 PEOPLE AGREE THAT RUSSIAN ROULETTE IS SAFE!
richard2717 is offline   Reply With Quote
Old 01-28-2018, 08:56 PM   #68
richard2717
Kevin
Kevin,
The rear holes center to center on the 67-72 brackets are roughly 44.25'' so you will have to do some mods to make it work, but since it is plywood floor it should be fairly simple.
Richard
Members I have met.
Old 01-28-2018, 09:42 PM   #69
mrtoni
Thanks Richard. Let me look at what I have bracketwise and I will let you know. Matt
Old 06-19-2018, 10:02 AM   #70
Bramante
great!
Bramante is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
