Old 10-04-2017, 10:31 PM   #1
70K10Hunter
70K10Hunter's Avatar
NP 203 to NP205
K so I've been scouring the threads on this and it appears to be straight forward just want to double check my info.....I have a 77 GMC 3/4 4x4 it currently has a 203 bolted to a TH350 I am getting a 205 that was bolted to a th350. Can I use my existing transfer case cross member? I'm assuming that I will have to move it back a bit. What about drive shafts?
70K10Hunter is offline   Reply With Quote
Old 10-05-2017, 06:27 PM   #2
Undone
Re: NP 203 to NP205
Cross member will work front driveshaft needs to be shorter and rear longer.
Undone is offline   Reply With Quote
Old 10-05-2017, 10:04 PM   #3
sweetk30
sweetk30's Avatar
Re: NP 203 to NP205
also make sure you get shifter parts . and adapters are t-case specific as with trans .
dont forget the female to female coupler sleeve for the 205 .
77-k30lb BIG truck build .
79-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
sweetk30 is offline   Reply With Quote
Old 10-05-2017, 11:02 PM   #4
franken
Re: NP 203 to NP205
Make a doubler out of the 203 range box...
Old 10-06-2017, 07:02 PM   #5
70K10Hunter
Re: NP 203 to NP205
I am getting the shifter, trans output coupler/adapter, and box.
the box I'm getting was already coupled to a TH350.
So I think I'm good.
Old 10-07-2017, 10:59 AM   #6
abig84
abig84's Avatar
Re: NP 203 to NP205
is it evengoing to bolt up? the adapter for the np203 is like a 1/4 inch thick where as the 205 is a few inches thick the transmission output shaft is going to be way to short
i wanted to run a np208 after i threw out my np203. i just brought the trans to a shop and had a longer output shaft installed
abig84 is offline   Reply With Quote
Old 10-07-2017, 11:08 AM   #7
70K10Hunter
Re: NP 203 to NP205
I guess I will find out when it gets here. If it is too short I will get a different one and install it when I rebuild the tranny.
Old 10-07-2017, 05:25 PM   #8
sweetk30
sweetk30's Avatar
Re: NP 203 to NP205
th350 with 203 or 205 use same output shaft length in trans .
the 208 and 241 used another length .
Old 10-10-2017, 11:59 PM   #9
El Dorado Jim
Re: NP 203 to NP205
it will bolt right up, you will need to move your crossmember and redrill holes in the frame if i remember right, I did this same conversion 30 years ago.
El Dorado Jim is offline   Reply With Quote
Old 10-11-2017, 06:32 PM   #10
70K10Hunter
Re: NP 203 to NP205
Yes fully figured on that, my frame on my 77 like my 70K10 has 2 brackets just aft of the existing cross member on each side with a bolt already in one hole. I think that is where the CM will go. We'll see.
That actually got me thinking I wonder if a drive shaft out of a early 70, 71, 72 K10 or 20 would work???
Old 10-14-2017, 11:19 AM   #11
abig84
abig84's Avatar
Re: NP 203 to NP205
interesting. like i said in the previous post my np203 adapter is like 3/4 inch thick the adapter i have attached to a np205 is like 4 inches thick, but its for a th400transmission
i just remember trying to put a np208 onto a th350 and that out put shaft was no where near long enough, just had a trans shop put one in.
didnt know it was a different situation with the 205s and th350. learn something new everyday
Old 10-14-2017, 02:17 PM   #12
sweetk30
sweetk30's Avatar
Re: NP 203 to NP205
yes th305 203/205 same output on trans .
th400 203 is short output on trans .
th400 205 is 2 diffrent output shafts for the fig8 style short input 205 or the round 6 long input 205 .
Old 10-19-2017, 10:10 PM   #13
70K10Hunter
Re: NP 203 to NP205
got my Tcase the other day I will check for fit this weekend after I pull the cab.
Old 10-22-2017, 12:09 AM   #14
70K10Hunter
Re: NP 203 to NP205
So I pulled my cab today and then pulled the 203. The 205 bolted right up to my tranny no mods needed. Before I pulled anything I marked the location of the front of the trans with a straight edge then mounted everything, used same mounts and did not need to move the cross member. Its all good, now just need to do the drive shafts.
Old 10-22-2017, 12:23 PM   #15
snj8198
snj8198's Avatar
Re: NP 203 to NP205
what's the length difference between the 203 and now the 205?
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 10-22-2017, 03:07 PM   #16
70K10Hunter
Re: NP 203 to NP205
the 203 is 22 1/4" and the 205 is 16" from mounting face to trans and to center on rear yoke.
so 6 1/4".
Copyright ©2000 - 2018, vBulletin Solutions Inc.
