01-22-2018, 07:57 PM | #1 |
57 gas tank relocate tutorial?
As you could guess I'm wanting to move the tank to the rear. Ive searched the forums and have found many pictures of rear tanks that are installed and which ones to use. What I haven't found is a post of how to actually do the relocating. It looks like I need to remove the bed from the truck but I have never done that before. Is it as simple as removing the bed and placing the new tank in and moving fuel lines? If anyone has links that will help me that would be much appreciated. I haven't worked on many vehicles before but I want to do as much as I can on the truck.
01-22-2018, 09:05 PM | #2 |
Re: 57 gas tank relocate tutorial?
removing the bed makes this job a lot easier. ..you'll need to remove the bed bolts and wiring..4 of your buddies can lift it off fairly easy..you'll need to fab mounting brackets for the new tank and reroute the fuel lines...you'll also need to figure out your fuel fill..
01-23-2018, 12:27 AM | #3 |
If you use a Mustang fuel tank it slips into the lower flange of the chassis and bolts down through the flange doesn't get any easier.
They are available from http://www.tanksinc.com the earlier tanks are 2" wider the nth '71 which is 30.5" wide and holds 20 gal. The '70 is 32 5/8" wide and is 22 gal. check them out .
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 Last edited by G&R's57GMC; 01-23-2018 at 12:36 AM. |
01-26-2018, 09:41 AM | #4 | |
01-27-2018, 06:48 PM | #5 |
Upside-down with the rails on 4-by's and some padding.
01-28-2018, 07:08 PM | #6 |
i stored the bed of 58 truk standing upright on the front panel for years
takes up a lot less room in the shop this way
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
01-28-2018, 09:51 PM | #7 |
Same as ogre, on 2 furniture dolly's from HF, easy to move around and doesnt take much room.
