Old 10-15-2024, 08:38 PM   #1
ron350
ron350's Avatar
Delco G1852 temp sending unit?
I am looking for information about the AC Delco temp sending unit G1852 - GM 12334869.
Several yars ago I read a discussion about how an aftermarket sending unit was some way better than what GM was selling.
Does anyone remember that discussion?
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is online now   Reply With Quote
Old 10-16-2024, 12:29 PM   #2
ron350
ron350's Avatar
Re: Delco G1852 temp sending unit?
Guess I will order a G1852 from RockAuto and see what they send.
Old 10-16-2024, 04:52 PM   #3
Slammed84
Slammed84's Avatar
A sending unit like this is just a variable resistance based on water temp. The gauge in the cluster senses that resistance and changes the needle position accordingly. FWIW, I've never found the temps to be super accurate on these 80's electronic gauges. I recently ordered the same sender from Rock Auto, and my gauge still reads way off.
So be prepared to be disappointed if your gauge still reads incorrectly. I do understand its not always appealing to mount a mechanical gauge in the cab though.
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
Old 10-16-2024, 05:13 PM   #4
ron350
ron350's Avatar
Slammed84 where did your G1852 from Rockauto say it was made?
Old 10-22-2024, 12:50 PM   #5
wazzabie
Made in mexico
wazzabie is offline   Reply With Quote
Old 10-22-2024, 02:42 PM   #6
Accelo
Accelo's Avatar
I have seen studies where the writer purchased ten of the senders from all different manufactures. Some were bad, others pathetic. I believe the AC-Delco is still your best bet.
Accelo is offline   Reply With Quote
Old 10-22-2024, 03:19 PM   #7
ron350
ron350's Avatar
Thank you just ordered a G1852 from Rockauto.
Old 10-24-2024, 03:49 AM   #8
wazzabie
I have both the Delco G1852 and the Lectric Limited which is advertised as having the correct resistance. I'm going to measure the temp in boiled water and resistance in each sender before installing.
https://www.lectriclimited.com/produ...ding-unit-116/
For Truck Years: 1974 - 1978
The Temp Gauge Needle Should Point to:
Left Line (Cold) when sender resistance = 350 Ω
Middle Line when sender resistance = 68 Ω
Right Line (Hot) when sender resistance = 46 Ω
Old 11-03-2024, 07:26 PM   #9
520CheyenneK10
I just went through this and initially I Purchased and installed the AC Delco G1852 and it sent my gauge to the RED and back and forth. I laser temped it and the sensor was actually way off. I Was not going to buy the OE part number 01513321 for over a $100, so I instead went to a parts house other than A-Zone or the such and found that they routinely sell the Standard Motor Products part number TS6 with no customer return or dissatisfaction issues and I have had zero issues since.
2017 Infiniti QX70
2015 GMC Yukon Denali XL 4x4
1993 Jeep Wrangler YJ
1973 Chevy Cheyenne K10 4x4
520CheyenneK10 is offline   Reply With Quote
Old 11-03-2024, 07:51 PM   #10
wazzabie
What year do you have? Standard Motor Products also has a TS5 which is just like the TS6 but different resistance.
Old 11-03-2024, 08:42 PM   #11
520CheyenneK10
1973 K10
Auto Trans.
Original SBC 350 Bored .030 over Mild RV Cam
2017 Infiniti QX70
