11-17-2024, 08:30 PM | #1 |
front axle 8 lug
Hello all,
anyone here have an front 10 bolt or 44 collecting dust? how about auto hubs. Mod,, move this is needed, THank you, Chris |
11-19-2024, 12:03 PM | #2 |
Re: front axle 8 lug
You may want to reconsider using the auto hubs as they are not all that reliable...especially in the colder climates
11-19-2024, 12:20 PM | #3 |
I hear that alot,,, I run a set on my 89 v2500 for ~600k miles and never had an issue.
With my Dentside, even with high pinion 44, the drive shaft angle is steep and not good at highway speeds. This is not a wheeling truck,, but in the snow ice it is nice to engage 4wd when needed and disengage when on the highway. |
11-19-2024, 06:22 PM | #4 |
If you go for a 10 bolt--try to get a later model out of a suburban as they will have a 30 spline inner shafts instead of the early 27s. With the 30 spline inners the 10 bolts are actually a little stronger than the D44s
11-19-2024, 06:50 PM | #5 |
Born Psycho
i've got one out of mid 80s suburban with 4:10s but i'm quite a distance from you. no auto hubs for me either, had to change to manual hubs on a colorado hunting trip (luckily i to a new set of warn hubs just in case)
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Today, 02:30 AM | #6 | |
I just grabbed a D44 and 14B myself. If you feel like doing the whole pull it yourself thing.
'72 Blazer, A/C, tach, tilt. Not on the road at this time '87 v30 Custom Deluxe, standard cab, SRW, Utility bed '86 c10 Silverado longbed (for now) '19 ecsb, 2500, 4x4 '15 Subaru Legacy - commuter |
Today, 10:44 AM | #7 | |
I drive past state street almost everyday,, I will stop in.. I live on Beacon light near the chevron,, You are local to boise? |
Thread Tools | |
Display Modes | |
