Old 04-25-2013, 08:58 PM   #1
monte0185
monte0185's Avatar
Tranny and transfer case.
Ok guys and gals. I bought this truck a couple weeks ago and still trying to figure things out. Hoping you can help. I know this is a 4L60E tranny and 205 transfer case but Im hoping you can help me with what kind of adapter is between the two and how I can get a vss in there? Im guessing im gonna have to buy the adaptor from AA that has the vss hole in it but what adaptor do i buy? The 4 bolt holes in the back of the tranny instead of 6 baffles me. Preciate your help!!
Terry J.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-25-2013, 09:27 PM   #2
monte0185
monte0185's Avatar
Re: Tranny and transfer case.
I just found this for a 700r4 and it looks like the same exact adaptor. If this is the case then has anyone installed a vss inside one of these adaptors or the 4l60 tailhousing?
http://67-72chevytrucks.com/vboard/s...=128495&page=2
Old 04-25-2013, 10:02 PM   #3
obijuan
You can put a 241 one it with vss in it. You can put a 4x4 output shaft into a 2wd trans but I don't know if the 4x4 shaft has provisions for the vss.
obijuan is offline   Reply With Quote
Old 04-25-2013, 10:48 PM   #4
monte0185
monte0185's Avatar
I found it finally!!! Been searching for 2 days !!!!!!! Sorry guys and gals if i took up your time but this is at least posted for posterity now!! Here is an adapter kit for the VSS on the 92-96 4l60 4wd transmissions with the 4 bolt pattern using a 700r4 adaptor.
http://www.advanceadapters.com/produ...-output-shaft/
Cheaper here.
http://www.northwestfab.com/4L60E-4L...ft_p_1588.html
Terry J.
Old 04-25-2013, 11:16 PM   #5
obijuan
that answers that. didnt know that existed.
Old 04-26-2013, 08:52 AM   #6
monte0185
monte0185's Avatar
Me neither. been racking my brain and spending alot of time internet searching and finally found it. Think I may end up buying another 4l60 from a 99-up after i get it all together and drivable. Go ahead and have it built with the 700r4 shaft and adaptor plate in case this one goes south on me. Now onto Wiring!! LOL
Old 04-26-2013, 11:27 AM   #7
Redcap
http://www.pirate4x4.com/forum/chevy...465-np205.html
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 05-20-2013, 01:20 PM   #8
low67chevy
that adapter is a tek pack fitzall adapter fyi they work money when doing the 700/205 combo build
low67chevy is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
