Old 08-05-2015, 08:31 PM   #276
picklito
Re: 2WD C10 Modern/Performance Alignments
Ok now I'm thinking that there are multiple locations for the hole. Depending on which one you start with, moving the hole 3/4" is probably not the best way! Putting it a 2" from the end might be the more consistent dimension?
Ya- diagonal groove. I wondered that, too.
picklito is offline   Reply With Quote
Old 07-26-2016, 08:23 AM   #277
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Subscribed
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-29-2017, 06:08 PM   #278
HO455
HO455's Avatar
Just wondering if BMERDOC got the caster modification done on his truck?
RIP Bob Parks.
Old 07-29-2017, 06:51 PM   #279
BMERDOC
BMERDOC's Avatar
I did do it but the truck is laid up after a front end rebuild, disc brake conversion and a general redo of the engine compartment. It should be up and running soon and the alignment done. I'll come back and report what I found.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 07-29-2017, 07:08 PM   #280
HO455
HO455's Avatar
Good to know. I just finished mine and got the initial readings on the alignment rack. Not being anywhere near accomplished at this stuff as you I look forward to your results. I'm pretty sure I can get it drivable but I may have wait for your results to make real improvements on the alignment.
RIP Bob Parks.
Old 08-18-2017, 01:31 AM   #281
HO455
HO455's Avatar
I was rereading your thread the other day and later it occurred to me you had been talking about milling several index holes to find the ideal distance. With your access to an alignment rack you could grind down the rivet in the saddle that indexes the shaft. After reassembling without an index, move the shaft around and find the best location to balance your alignment and the shim stack. Obviously you couldn't drive it that way but as a test bed it should work. When you are satisfied mark and mill your new index holes. Then it would just be a case of drill out and replace the rivets with more positive indexing cap screws
I drilled my rivets out after I found one side half sheared off and no way to positively position the shaft. When I looked at the other side I found that there was approximately an 1/8" of play between the rivet and the index hole. By machining the new hole to 3/4" and using a 1/2" cap screw I now have virtually no play. I did have to shorten the head of the cap screw as my index holes were not deep enough. Anyway its just a thought.
RIP Bob Parks.
Old 08-18-2017, 06:57 PM   #282
BMERDOC
BMERDOC's Avatar
Thats not a bad idea. I had thought of having a machinst drill the indexes, machine a groove connecting the two and machine flats on the shaft so it could be infinitely adjustable between the two positions.
Unfortunately, I am now a Realtor and no longer have the play time I once had with an alignment rack. I am working on finding someone that will let me rent a rack to experiment in my free time.
Nick Carter
Old 08-19-2017, 02:35 PM   #283
HO455
HO455's Avatar
Sounds like big life changes. I hope it works out well for you. I look forward to your updates when things start rolling again.
RIP Bob Parks.
Old 08-20-2017, 12:25 PM   #284
clay68c10
clay68c10's Avatar
I'll be doing the multiple holes in the cross shaft eventually, it will probably be a while before it's at a point where I can drive it and put it on the rack at work.
Had to get out of the flat rate world? Me too, I fix police cars for the city now.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-24-2018, 02:25 PM   #285
0bad0boy7
Originally Posted by BMERDOC View Post
Ok. I had time to tinker so after swapping the upper control arms side to side. Here are the results. I think this debunks the thought that the uppers can be swapped. Yes, the caster is excessive and could be brought to 8 or 9 degrees by adding about 9/16" to 5/8" thick shims to the rear but the camber is already positive and can't be remedied. Time to swap the uppers back and notch the lowers....
This quote is from post #74
It looks like the swapping the uppers gave you a gain of approximately 10°. I could really use a 10° increase of caster since I am at -4° on both sides now. I just replaced all the suspension parts and perhaps the previous owners of the truck reversed the arms. Thanks for the detailed posting on this thread.
0bad0boy7 is offline   Reply With Quote
Old 01-24-2018, 03:39 PM   #286
BMERDOC
BMERDOC's Avatar
Nothing wrong with swapping to see what happens.
Nick Carter
Old 01-24-2018, 07:38 PM   #287
0bad0boy7
So I replaced all the suspension parts on my 1966 C10. The front seams to have been donated from a 80's C10. Problem areas are underlined
After replacement I had:
Camber: 0.1° and 0.4°
Caster: -4.4° and -4.8°
Toe: never a problem setting
After swapping the upper control arms my caster was great, but there was not enough room for shims on the bolt to fix my camber:
Camber: 0.5° and 1.4°
Caster: 5.7° and 6.9°
So I guess the best idea is to swap the upper control arms to there correct position and just live with the negative caster. What do you guys think?
Old 01-24-2018, 08:05 PM   #288
BMERDOC
BMERDOC's Avatar
So did you have any shims on the bolts after all the parts were replaced? You have a very odd situation.
Nick Carter
Old 01-24-2018, 08:17 PM   #289
0bad0boy7
I replaced the shims when I reassembled the truck and the camber was visible: tops pointed out. I came down on camber, into spec, when they were all removed.
After reversing the upper arms, I still had no shims, but the hunter machine was telling him to add more to the passenger side to get the caster and camber even, but there was not enough thread to add more than 1/2" shims.
I'm not sure what to do with this. I have already spent so much time and money on the suspension of this truck. I think I will have to just live with the -4 degrees negative caster and hope for a year to come when I can afford a complete engineered system like RideTech or something similar.http://67-72chevytrucks.com/vboard/i...ilies/waah.gif
Old 01-24-2018, 08:43 PM   #290
BMERDOC
BMERDOC's Avatar
The problem is that even if you invest in an expensive system like ridetech it might not fix your problem.
Nick Carter
Old 01-24-2018, 09:36 PM   #291
BMERDOC
BMERDOC's Avatar
Hey badboy post some pics. Maybe that'll help.
Nick Carter
