Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 05-26-2015, 01:58 AM   #1
80SPORT
80SPORT's Avatar
1970 C50 with Holmes 500 wrecker
We picked up a very original C50 with a Holmes 500 twin boom wrecker from one of the towing companies;38000 original miles...belonged to a Chevy dealer ...just used for towing their own units...rigged up at the Holmes factory.It has the Accuride 25647 RH 5 deg rims on it ....we will have to find some 22.5 one piece rims as the tire stores here will no longer change out tires on the 2 piece rims.Everything else we can keep correct.350/2v with a 4spd/2 speed axle ....even has the linkage assist power steering and factory tach.
80SPORT is offline   Reply With Quote
Old 05-26-2015, 08:00 AM   #2
Re: 1970 C50 with Holmes 500 wrecker
Custom cab to boot! Nice nice nice. I decided to sell my C/30 wrecker because one like this is what I feel I need to haul my 10-30s. You done good Jethro
Old 05-26-2015, 08:42 AM   #3
C10 - C90 Bill
C10 - C90 Bill's Avatar
Real nice truck. Back in the Mid-70's I was looking for one exactly like it. I was slow on work and saw an opportunity to make some money with it. That Holmes 500 is one good Wrecker unit.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 05-26-2015, 02:17 PM   #4
junksaver
Nice looking wrecker. Do you have any more pictures of the bed? It appears you may have a Holmes 600 wrecker bed on the truck. I would like to have that in my Wrecker collection.
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 05-27-2015, 01:17 AM   #5
80SPORT
80SPORT's Avatar
Definitely a Holmes 500;has the optional larger drums and outboard legs;installed new on the truck in 1970.The SPID shows the Z62 custom cab.Most wreckers were used hard and worn out in the first 10 years;this is one of the most original and correct Holmes units I have seen.
Old 05-27-2015, 01:21 AM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
Sweet little tow truck.
Old 05-28-2015, 07:59 AM   #7
68panelman
68panelman's Avatar
Very nice rig, Good luck with it.
68panelman is offline   Reply With Quote
Old 05-28-2015, 02:39 PM   #8
junksaver
That is an unusual Holmes 500. All the 500 models I have seen were the same as a 480 just with a gear reduction on the winches. Yours appears to have all the specs of a 600, but is tagged as a 500.
68 4wd Stepside
73 4wd Blazer
Old 05-29-2015, 02:04 PM   #9
kwmech
Wouldn't a 480 be a little small for a medium duty chassis? I've got a 480 that I recently removed form a 30 series
Old 05-29-2015, 02:55 PM   #10
junksaver
I have a 480 mounted on a 72 C30 and it is wider than the rear chassis. It could be mounted on a C50 but would be on the light duty side for a chassis that heavy.
68 4wd Stepside
73 4wd Blazer
Old 05-29-2015, 03:42 PM   #11
C10 - C90 Bill
I have a Holmes 440 (Single Boom) and once had a 480 (Twin Boom), both on 1-Ton Trucks. I believe the 500 is for Medium Duty trucks, but a quick call to Holmes would tell us all for sure. I contacted them once with the numbers on my 440 and they deciphered them all for me. Very friendly people to boot.
GMC 9500 Fan
Detroit Diesel Fan
Old 05-29-2015, 04:47 PM   #12
undertaker72
undertaker72's Avatar
my 500 has one large spool and a small and pass only stiff leg, your has both and large drums , tailboard looks like it set for car sling and a med duty sling , did you get the hand cranks , 500-600-750 holmes all have the same gearbox, just larger mast and booms , I had a 600 bed on a Kodiak with extendable booms square tube , the lattis booms are just as strong , just short on reach , ill tell ya if you can glue any of them down they will pull till you rip the causulty apart or bust a pto shaft , they outpull a hydrolic all to hell , that's why you see a lot of holmes mast on kemp conversions , that's a nice piece you have there
undertaker72 is offline   Reply With Quote
Old 05-29-2015, 07:48 PM   #13
kwmech
That's what I thought, need any parts? I'm going to scrap out the 480. I'm keeping my 440 on my 4x. Of all things I'm using my wrecker for logging right now, Calif won't let me use my truck for commercial towing anymore due to the weight rating of the truck. I'm going to be selling my other truck soon, just has a wheel lift on it
Old 05-29-2015, 07:52 PM   #14
kwmech
You're not kidding on the strength of the units, I'm constantly surprised how strong just my 440 is. I upgraded the cable to 1/2, it will keep pulling until something breaks or starts dragging the truck
Old 05-29-2015, 10:23 PM   #15
80SPORT
80SPORT's Avatar
The 500 was available with one small drum and one large drum;it was called the Town and Country option;I have the car sling as well ...as you can see from the brackets.The 500 was the smallest of the heavy duty line consisting of the 500/600/750/850 series;we did have one 500 on a one ton but it was too much wrecker for the truck;the 440/480 were a great fit on the one tons.In the 70's Holmes was the world leader in recovery equipment;even todays super hydraulic rotators would have a hard time outdoing an 850 mechanical on a straight pull...you might snap a cable or bend your truck...but you never broke a Holmes wrecker.
Old 05-29-2015, 10:42 PM   #16
undertaker72
another good thing holmes did was the pan dollies , in the old days you caould take a care that was a pancake if you had the dollies and the truck , the new pop ups are a lot weeker than the good old stuff , if you wanted to do a super pull take the cables of the boom and do a mast pull , 2 part lay-up to a couple deadmen and you could move some iron , why don't you sell me that that's a cherry rig
Old 05-30-2015, 05:45 PM   #17
1976gmc20
Congratulations! Very nice old truck
I had a 1965 C-50 and I changed the tires on those 20" two-piece rims myself all the time. I used it for hauling logs so I had lots of flats, but I never had any problems with one blowing up. You just have to know what you're doing. Just FYI
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 05-30-2015, 11:32 PM   #18
colgad
colgad's Avatar
Part Number 40016-11 22.5x9 at the Truckaccessorydepot $225. each fits your C50!
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 06-08-2015, 02:45 AM   #19
greywuuf
KwMech, I may be interested in parts.... is it complete ?
greywuuf is offline   Reply With Quote
Old 06-08-2015, 12:37 PM   #20
kwmech
yes but it needs some TLC. I was going to build strictly and off road unit but couldn't get the money together for the build
Old 07-21-2017, 09:17 PM   #21
djaap
Nice wrecker. Want another one? 1970 C40 with a Holmes 500. Comes with a big Boom as well. Truck still runs. Engine has a knock. Hasn't been used on the road in decades. My father used it to move around cars in his paint and body business. Wrecker bed is extremely useful for lifting off truck cabs, beds or as engine lift. Single speed rear end, not much fun to drive on the road. I have no idea what a fair price for this truck is. Sorry some pics are upside down. I am too lazy to fix it.
Anybody know what a reasonable price is for this truck? My father is too old to use it anymore and I don't work on vehicles that much myself anymore.
djaap is offline   Reply With Quote
Old 07-23-2017, 06:36 AM   #22
Very interesting. On value I'd say it's worth less than he paid since it's upside down.
Old 07-23-2017, 07:35 AM   #23
djaap
Thanks. I really struggle sometimes with computers. Let me try again. Didn't work.
Pic is fine when I upload it.
Old 07-23-2017, 08:06 PM   #24
greywuuf
I would love to find one like that near me.... I missed one that went for a Grand a couple years back
Old 07-23-2017, 09:43 PM   #25
djaap
A grand will buy this one.
