Old 07-09-2017, 07:38 PM   #1
$20071k10
$20071k10's Avatar
56" spring swap thread
can any some one please point me to a informative 56" rear spring swap thread? can I swap sides with the ORD shackle flip with 4" shackles and get the desired length for 56" springs and proper shackle angle? I don't want more than 5" of lift. or do you have to redrill frame? thank you in advance!
Brian
$20071k10 is offline   Reply With Quote
Old 07-11-2017, 03:32 AM   #2
'63GENIII
'63GENIII's Avatar
Re: 56" spring swap thread
Pretty sure you need to re drill the rear hangers. I think the fronts stay put though.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
